LTDSC Build Thread
Installed my lower links this morning in under an hour. Really easy install, high quality products.
Against stock links
Installed
Next up is lengthening my rear sway links to even it out and get the upper links as well.
Assembling my links hoping to install tomorrow. These turned out pretty nice. Still need to go get the hardware.
Good s^*t Sam !! I guess peps think a blue modded 4r can't bad enough to win ? Sleeper 4r that wheels folks !!!!!!!!!!!!!
Ok heres the parts list and my installation information/pics
I took this parts list from Toyota120 so ill copy and paste what i used.
Energy Suspension kit (Part #9.8121R) which I got off amazon.
McMaster-Carr
Qty 1. ASTM A193 Grade B7 Alloy Steel Threaded Rod, Plain Finish, 3/8"-24 Thread, 2' Length; Part number 98957A805
Qty 2. Steel Ball Joint Rod End, 3/8"-24 Right-Hand Female Shank, 3/8" Ball ID, 13/16" L Thread; Part number 60645K341
Qty 2. Zinc-Plated Steel Washer for Ball Joint Rod End, Fits 3/8" Shank Size; Part number 95034A300
Lowes
Qty 2. Grade 8 3/8" 2" length bolts
Qty 2. Grade 8 3/8"-24 Thread nylock nuts
Qty 2. Grade 8 3/8"-16 Thread nylock nuts
Qty 2. Packs of 3/8" grade 8 washers
Qty 2. 3/8x1/2x1-1/2" Steel Spacer
Red Loctite
Pre Assembly
Stock comparison
Sleeves for the stock sway bar to protect the threads of the new bolts.
The overall Eyelet to frame mount should be 6 1/2" so instead of cutting the bushing like others have, i cut the sleeve down a hair. The heims add about an inch if not a little less so you'll need to do one or the other. I refused to cut a perfectly new bushing.
Measurement for what length you want the sleeve to be
All combined, back at 6 1/2" like desired.
Installed (notice its now parallel to the lower link. Definitely an improvement from the OEM link angle.
Very easy installation and build, i highly recommend them. Im only in this about $40.
Flushed out my power steering fluid. It was pretty damn gross. The noise i had, went away. I had a little groan from take off and figured i'd start with the fluid.
went up to the mountains this past weekend, wheeled a bit. Suspension is perfect, theres parts where i was 60mph+ and it was smooth as glass offroad. Very impressed. Now i just want to strap the front and add a better bump stop up front.
<iframe src="https://player.vimeo.com/video/132767351" width="500" height="281" frameborder="0" webkitallowfullscreen mozallowfullscreen allowfullscreen></iframe>
Started building a box today. To fit comfortably within the side of my cargo area. I've had the 8" in factory location which I explained and showed in the beginning of my build. It was time to move on to bigger and better but still not take up a lot of space because I use my cargo area almost daily.
I got half way through this before I decided I should take pics so this is all I have.
Tomorrow I'm going to carpet it to match existing tan carpet. Also going to close off the box a bit, take the cubic feet down a touch as the sub only needs 0.80 (minimum)and its sitting around 1.25 right now. Maximum is 3.0
Ill update this tomorrow with progress.
I like the Amsoil!! Getting ready to change the trans and PS fluid this weekend to Amsoil. Rig looks great, you've been busy!
What song is that in the video?
Renegades by X Ambassadors
Finished up today. Very happy with how it turned out. I closed off the box to 0.90 cubic feet for optimal sound. Carpeted it up and fully secured it. I'm happy with it.
I went with a Kicker CVT10 because I had it in the garage lol
Oh I see now, didn't even look at the floor just the box, I like it though. I've been wanting to do something about my sub since its blown and the box is huge and in the way
Bill15163
