LTDSC Build Thread
Oh I see now, didn't even look at the floor just the box, I like it though. I've been wanting to do something about my sub since its blown and the box is huge and in the way
I use my cargo area a ton so I can't have a normal box. This was roughly $60 total and about a days worth of work.
Just like the rest of your build it looks thrown together and not clean....
:wink2:
Excellent job as always sam
Thanks!
I think I see some sarcasm [emoji23][emoji23]
its secure through the inside. I have a bolt in the front to the wheel hump as well as two in the wall to the side panel. I had to buy a sleeve and cut it to size to fit between the wall and the panel because the panel archs. It hasnt moved since i installed it.
it was an attempt to keep it all internal and clean looking from the outside.
Thanks.
4runnner looks really good.
That's what made my final decision to want to do a pre runner-ish build.
I might have to get a sub setup like that too, but have one on both sides.
Got my oil tested and was curious as the results since the miles and running 10k intervals on Amsoil. For those that are curious.
Excellent results [MENTION=87687]LTDSC[/MENTION], thank you for posting!!!! So happy to see how well Amsoil is protecting your engine and the great comments from Blackstone. I was even more impressed when I saw that this was from Amsoil's XL line, not even the Signature Series. At 10,000 miles your engine is getting protection than oil changed out at 6,700 miles with less wear metals shown!!!
Well that's good news. I hope this is what my results look like, I have a kit in the mail right now. How long have you been running 10K intervals? I've just been using my maintenance light as a reminder and I think it's every 5k. Now I'm thinking I should let mine go another cycle to get a better sample.
Ive ran 10k intervals since i got it at 94k 3 years ago. I know when my maint light comes on, i am half way through my cycle. I just reset it and i keep track of my miles in an app i use for fuel MPG/tracking so it keeps my maintenance records as well as reminds me when to do certain services.
What app are you using? I use the Toyota Owners app and its not bad but it doesn't give me any updates or notifications. It's basically just a log of my service history.
I have an iPhone so i use Car Minder, on android i used aCar.
These showed up. Very excited to put these on.
What's your plan for the lower anchor? I've been debating whether I want to add an anchor to the OEM LCA or I was also considering having custom LCA skids made with an anchor point but I'm not sure if it will hold the weight.
Just going to attach it to the the coilover bolt which is already a grade 8.
tssawlson538
