Lube
just some gool ole WD40 on the rear door shocks and same with hood. For the 4 doors, I will use the same grease as I do on the swaybar bushings.
+1 for the 303 aerospace protectant. It's fricking awesome stuff. Made near where I grew up too. Never found anything better than that stuff for rubber, plastics, vinyl, etc...
For years, on many cars and now the T4R I have used the tire spray like Armor All (not really sure what brand I have now). It works great to condition the rubber and in the winter time after a car wash my doors are never frozen shut.
interesting, I think I will give it a shot... Might i ask why you use the tire spray over armor all?
Maybe I misspoke, I use the Armor All Original Protectant Spray, like this;
Ahh, I wonder though if you use the tire gel on the plastic molding. Since I have the sr5 my entire lower body is basically plastic molding. I wonder if it would offer any protection.
Eh just a thought.
Thank you!
I used to have a 97 Jeep GC with the same plastic molding on the bottom and yes it works. It is slower to soak in to the plastic but is clearly looked a deeper gray than before it was applied.
One winter on the GC I pushed in a corner of the lower rear bumper. I heated the bumper with a low temp heat gun and pushed out the dent with the rounded side of a crowbar but it left a whitish circle around where the dent was. I just used the protectant (again not sure what brand I actually have in the garage) and the circle was gone in a few days.
Unless the Armor All formula has changed, it's a petroleum based product. Once applied, it'll need to be applied repeatedly to prevent drying of the rubber/plastic parts leading to cracks.
If you stop using 303, it won't lead rubber/plastic parts cracking.
tuṣṭāva
