Lumbar support switch does not work
toytruck
Is there a fuse I can replace to make it work? or is the motor just broken? Anyone ever have this problem:bash:? If so, please chime in. Oh, it's a 2000 limited btw . Thanks..
2nd the motion
My new 4runner also has a lumbar support that doesn't work. What is the troubleshooting procedure for this? Anything comon?
Thanks,
Mike
:shrug: it's pushing up on my lower back and it sucks! i havent had time, but I'm going to try and look under the seat to see if there's any loose wiring. Love my truck so far though:driving:
Same here...I don't really care if it ever works, I just need to adjust it one time so it is not pushing into my back so much.:whipping2
I know that this thread hasn't been active for a while but I just noticed mine isnt working, any input on how to get it working?
I also would love to have a testing procedure or a way to move mine back...it has never worked and for my fat body it is too tight!!
I have a 99 with the same problem. I tore into it and found a stuck motor. There is a little slop in the worm gear that could cause it to bind up on itself. I freed it and it worked but it was weak. It got stuck again a week later. I find that if I don't max it out forward or back that it doesn't get jammed. Either way the motor is weak and its so quiet you can barely tell its moving. I took a picture of it but can't seem to find it now. The seat cover does come off fairly easy, really only a 5 minute job to get into the motor.
Mine works but hangs out. Can't for the life of me to get it into position so it stays in the seat. Grrrr! Gets irritating when it gets caught on the seatbelt and trying to wrestle it so I can get buckled up.
How'd you get into it?
I messed around with the switch earlier and had no noticeable change, but when i put my ear right next to the seat, I could hear the motor working but sounded very weak, I got the lumbar support to adjust just enough so that my back isnt uncomfortable anymore..honestly i could give a sh*t less if the motor took a sh*t on me and stopped working for good. :bigok:
I just found the pictures from when I did this. The leather seat cover isn't hard to remove. I unhooked the back edge and worked it up far enough to get to the motor. You can see the extra space on either end of the worm gear, it shifts end to end instead of staying in place like it should. Never found a good solution, just freed it up, helped it with the channel lock while holding the button to where I wanted it and left it.
Here is the motor with the cover opened, the worm gear is what was jammed up.
Location in bottom right corner of seat back. Channel Loc on arm to coax the motor into moving again after it got stuck again.
My lumbar has never worked, because the switch isn't connected to anything. At the bottom of the seat back I have an open plug. Is there are jumper wire from this plug to your switch?
Thanks,
Drew
Thanks,
Drew
Does anyone have a pic of the wiring behind the seat cover (see above)?
Thanks,
Drew
Does anyone have a problem with the seat back incline/decline not working? My left side seat back is higher (more inclined) than my right side and is tweaking my back!
