Magnetic Grey 4Runners! Lets see them!
Dam you gobi rack wait time!!!!:redbrick:
didn't wanna hit like on that, but i do like that first pic tho
what springs did you add to the 5100s?
have a set of 2.0 superflex for the rear and debating on what to go with up front.
also debating the 285/70 KO2s or the 255/80 ST-Maxx.
i thought that wire coming off the pole was some super long antenna on your hood at first.
after some new tires.
i ran the toytec 2.0 superflex for the rear and OME's up front.:yo: and U.R. UCA's
lol at your antenna comment!
Recent Purchase
Got this 2013 TE in the last 2 weeks and had the opportunity to take her to Uwharrie National Forest in NC. Does equally well in the parking lot or in the mountains....
Just bought a magnetic Gray 2016 SR5 4 runner due to third row option but really like the TRD rims. Will the rims below fit stock tires on a 2016 Toyota 4 Runner
Set of Four 4pc Toyota 4Runner 1984 2015 TRD Pro SEMA 17" Black Alloy Rims Set | eBay
i can see you are new, and even worse a Bama fan :puke: (jk)
but check out this thread that is stickied in the 5th gen forum:
Modifications, Write-Ups, Quick Links, and FAQ's
it houses all the threads about almost every piece of your 5th gen. Go ahead and check out the "Tire fitment" thread, and it will give you the specs on your stock rim, then compare to the one you want to buy.
spoiler alert: many many many members on here run those rims. they will fit. It is 1/2" wider though, so i bet your next question is "but but but will they rub???" and that is for you to find out then to rectify with an easy fix for tire rub housed in the linked sticky above.
happy hunting! :hippie:
Another magnetic with gunmetal wheels. I am tired of seeing black wheels on everything, including the 50 JKUR's I see every day on my way to/from work.
I can tell you that those are FAKE TRD Pro wheels. First the OEM TRD Pro wheels are 17x7". The ones you listed are 17x8". Second, the OEM ones are more of a matte color and the ones you listed are glossy. So if you're going to get the TRD Pro wheels get the OEM ones and if you're going to get look alikes then get the FN Wheels version.
Been lurking for awhile & going to begin miss & having fun so I thought I'd pull the trigger & join.
