Manual Transmission Slipping
MDTrailrider
My 5 speed manual transmission on my 98 SR5 4Runner is starting to slip when driving up steeper grades. It has 268,000 miles. I've felt it briefly every now and then for the last year but wasn't sure it was the transmission or something else causing a miss or something. I replaced the plugs initially. This weekend it clearly slipped a couple of times when downshifting on relatively steep uphill highway grades.
Should the 4Runner need anything other than new clutch plates to fix the slipping? What can I expect that to cost? Should I take it to a Toyota dealership or a local garage? They both seem to have been reasonably fair and performed previous work okay.
call them any ask for cost.. you will want flywheel clutch disk and pressure plate and throwout bearing. good time for trany flush too
Best price i found on a clutch kit was from rockauto. It was made by Aisin in Japan. I wanted the marlin crawler kit but it was out of stock with no eta. If you take it to a private shop it might be cheaper to supply your own parts, some shops have a hell of a mark up on parts. On another note, where's the trails at here in Md? We usually ride up in Pa in the trevorton/schmokin area and we hit Hatfield Mccoy every year. Would be nice to hit some trails closer to home.
Looks like the kit from marlin crawler is now available, thanks 3rzrunner. When i was researching clutch kits for my taco i read a lot of good things about their kit.
yep I love my marlin kit and rebuilt w59 trans, but after 8 months I am STILL waiting for some logos and small parts that i have PAID for.....
Their customer service is total BS. I have called over 70+ times and have only got through once and the guy was very rude and stuck up. Sent countless emails and faxes with no reply.
I agree. I'm on their emailing list to be notified when their clutch kit is available but no email yet and that was almost a year ago. I'm happy with the OEM replacement Aisin kit from rockauto. I tow a travel trailer with my 3.4L 1st gen tacoma 4x4 and the clutch has performed great.
Just did my clutch Feel free to PM me with any questions if you decide to tackle it yourself I did mine myself about three weeks ago, here is everything I used, cost was under $700, my Toyota Discount helped quite a bit though.
From Marlin Crawler:
Heavy Duty Clutch Kit (1,200 lb) x1Kit
SKU: MCCL-129
Application: 6cyl 1996-2004
(Includes Clutch Disk, Pressure Plate, Pilot, and Release Bearings)
Clutch Fork Boot for 1995-2004 R150 x1
(Mine is currently very brittle and kind of crumbly)
Heavy Duty Shift Lever Ball Seat x1
SKU: MCTM-522
(I suspect mine is ready to be replaced as I have 210k on the clock)
SKU: MCTM-523
(Again, It's just time I figure I'll have the lever out anyway.)
Heavy Duty Shift Lever Socket x1
SKU: MCTM-532
(Might as well, it's probably trashed anyway.)
Heavy Duty Pressure Plate Bolt Kit (6 bolts
SKU: MCHT-411
From Toyota:
Flywheel x1
13405-62030
(Everybody says OEM is the best one so I coughed up for it, I don't want to resurface my old one)
Clutch Fork x1
31204-35031
(I've been hearing strange sounds and am afraid my release bearing has spun and damaged my fork fingers, if I can I will reuse my old one.)
Transmission input shaft seal x1
90311-32012
(Recommended by a few places)
Rear Main Seal x1
90311-92010
(Highly Recommended)
Throw Out bearing Clips x1
31232-35030 and 31232-35040
(Only one will be used, was given two options and I could find which so I ordered both, will return unused one)
Fly Wheel Bolts with loctite x8
90105-10138
Flywheel Sheer Pins x3
90250-08120
Misc:
Black FIPG from another job
Lot's of brake cleaner
Hand tools, will refine a list of exactly what I used as I use it
242 Locktite
I have marked a paint line on all rotating assemblies reachable without dis-assembly in order to properly realign everything upon reassembly.
Guides I will be useing:
5VZ Clutch Job - TTORA Forum
Toyota 4Runner Clutch Replacement on 4x4Wire.com
4x4Wire - Toyota Hydraulic Clutch Assembly Maintenance
SKU: MCCL-129
SKU: MCTM-522
SKU: MCTM-523
SKU: MCTM-532
SKU: MCHT-411
From Toyota:
Flywheel x1
13405-62030
Clutch Fork x1
31204-35031
90311-32012
Rear Main Seal x1
90311-92010
90105-10138
90250-08120
Misc:
242 Locktite
I don't have time to do it myself. If I did I would go hunting or dirt riding more than I do.:pray2:
This list is getting beyond my vehicle repair abilities. I do a lot of my own work but I wear a white collar so I have to draw the line somewhere. I guess I have to look at the repair manual and compare each part number to the illustration.
What should all this cost from a dealer or local shop approximately?
I would recommend the marlin crawler clutch kit. I have it and its awesome!
https://www.marlincrawler.com/clutch/heavy-duty/heavy-duty-clutch-kit-1200-lb
it would be this one 6cyl 1996-2004, (p/n: MCCL-129), $299.00
This is tempting but I will probably just stick with factory replacement parts. My 4Runner has been very good to me and it has always done what I needed it to except the eight or so times I've gotten high centered in deep snow. That has always been in the driveway though and I just took a few minutes to dig it out
I use my 4 wheel drive as needed for hunting, dirt riding and getting to and from work in the snow. I ride my bike where rock crawlers crawl.
There's no place nearby anymore. My friends and I got our bikes plated and we ride in GW National Forest, Greenridge SP, Bald Eagle SF in PA near State College, and we've trailered our bikes to Colorado, Utah and Wyoming. I've never been to Hatfield McCoy but it sounds like it's become too shredded and washed out for me. With plated bikes we can ride trails, jeep trails and forest service roads. They're all fun.
You can still ride at Trevorton/Schamokin? We used to ride on the other side of I81 near Lewellyn before the greenies got control of the area and made it worthless.:barf:
I've also taken my bike to Tennessee a few times and ridden with friends at Windrock and ridden by myself in Chuck Swan SF.
I hear ya, I'm not saying I really wanted to do mine but the dealer quoted me like nearly $2000 for parts and labor and I barley trust the dealers, that's why I do all my own work, or at least as much as I can. Besides I wanted to be able to say "Yeah I did my own clutch." all cool like. My truck is my hobby for the time being also so what else would I do with my free time?
A local Shop Quoted me about $650 in labor and parts where up to me, I know most guys spend about $100 get their fly's resurfaced alone, I replaced mine outright with new as I couldn't find a recommended machine shop that would do fly's in my time constraints.
I believe it's billed as a 9hr job so take your favorite shop's labor rate and multiply it by 9.
JUST MAKE SURE YOU HAVE THEM DO YOUR REAR MAIN!
