Marlin Crawler bushings and socket?
Yes they work great. I just did mine because they were cheap not that I had any problem. When I dug into the shifter to replace them what did I find... there was a marlin bushing already in there! I replaced it anyways since I had it.
It's an easy project. The only part I puzzled on a little is when you get right down to the last collar holding the shifter in. You need to push down and turn 1/4 turn left. It's an hour job if you take your time.
great thanks! Was the old Marlin bushing deteriorated at all?
The "old" new bushing was in fine shape. The feel of the stick might be a tiny bit tighter but I just want to think so because I did the work. Like I said... I didn't have a problem anyways but at 200K I figured I just replace it as preventive... but the PO beat me to it.
So I opened it up last night and took out the worn bushing and broken socket and put in the new Marlin Crawler parts. The updated socket and seat helped out a lot! I used to be able to make about a 4 inch circle with the shifter and now it's down to about 1 inch. Very happy with the upgrade/repair.
patnewton
