Master cylinder/ booster question
mmml4
Now that I have disc front and rear I need to address the lack of pressure at the rear. I have looked at 1998 T100 1 ton and 1997 Land Cruiser master cylinders. They both have an increase of bore size with no proportional valve but have a 4 bolt pattern. Our master cylinders have a 2 bolt pattern so no can do. Then I thought well I might as well use the matching booster and my problem is solved, but.
Has anyone used a booster from another vehicle in their 4runner?
OR
Does anyone know where I can get the bolt pattern dimensions of the Land Cruiser or T100 boosters?
I have a friend at our local dealership and he says the TIS system does not show the dimensions I need.
I also thought about going into my master cylinder and disable the proportional valve so I can get full pressure.
Any thoughts or suggestions are welcome.
I didn't realize what you did to have front and rear disc brakes and I gotta say I like what you did to your 4Runner a lot. If I find one like yours in the beginning I might be inclined to go your route but for rear disc brakes without swapping axles I found this thread http://www.toyota-4runner.org/3rd-gen-t4rs/106636-rear-disk-brake-conversion-pt-1-a.html and it looked simple enough and I could get these parts for cheap. Thanks for the help
Maybe this is a dumb idea, but could you make an adapter plate to go from 2 bolts to four and run the factory booster with the TLC or T100 master? You'd probably have to make a custom length push rod to make up the difference in the adapter plate, but that would be relatively simple.
***EDIT*** JFYI....I am swapping in an FJ80 front axle out of a '91 model. The MC bore size for an '91-97 FJ80 is 1". The 3rd Gen Runner uses a 1" bore MC from the factory. The '98 T100 1 Ton Non-ABS MC is 1 1/16"....so at least there's a bore increase to that.
JFYI....the guy in the Pirate thread also swapped a Tacoma 4 bolt booster to work with the T100 1 Ton MC. Not sure why he didn't just use a booster off the T100 too (maybe he couldn't find one...I tried Toyota Parts Online and it didn't have one available for the Non-ABS 1 ton....the 1/2 ton models were over $750!) Tried to get clarification on what year Taco booster he's using.
I'm wondering if one couldn't use this master from Wilwood http://www.polyperformance.com/Wilw...1&multi1678=95793&multi1679=95804&multi=26384 with a 1 1/8" bore and bolt it up to the stock 3rd Gen 4Runner booster....the MC on my '99 Runner looks really close to the 3.22-3.40" 2 bolt mounting pattern for the Wilwood unit ***
I'm wondering if one couldn't use this master from Wilwood Wilwood Aluminum Tandem Chamber Master Cylinder | POLY PERFORMANCE with a 1 1/8" bore and bolt it up to the stock 3rd Gen 4Runner booster....the MC on my '99 Runner looks really close to the 3.22-3.40" 2 bolt mounting pattern for the Wilwood unit ***
Did you ever end up using the Wilwood MC?
Sure tundra brakes are bigger then 1ton axle brakes and then d44 brakes. I know for a fact toyota v6 caliper on Soild axle are alot smaller then 4runner. I think it should work out fine
MaximussK
