Master cylinder grinding noise
bla1323
I started my 4runner up today and as soon as i turned the key on my I heard a terrible grinding sound, I could also feel it in the break peddle. The red metal hose has a lot of vibration. Do I need an entire new unit? Can I fix it another way? If you need more information or want a sound clip let me know. This is my daily driver and need to fix this quick.
brakes fine still? pedal hold pressure? they just do that. The pump in the unit makes a grinding noise and it's usually normal.
Breaks work fine. This is a very loud grinding noise that I've never heard before. Definitely out of the ordinary.
Sounds fine to me... isn't it supposed to make that noise? Looks like normal operation to me.
Well it's pumping all your fluid down. Where's that going? Sounds like a normal pump to me. Mine runs a few seconds every key cycle and has for the past 2 years I've owned it.
Doesn't sound all that bad to me, a bit more noise than mine makes but not by much, it could be that the motor brushes are dirty, which if you're mechanically inclined you could remove the motor and disassemble it and clean up the brushes, brush holders and armature contact area.
Most parts of the master cylinder assembly are not sold separately but you can but a new OEM pump motor, I have seen them on eBay for around $500 +/-.
Is the sound continuous, if so that's not normal, once it acheives the proper pressure the sound/motor should stop pumping until the pressure drops below the requirements to assist the braking process?
When I turn on the ignition mines run for about 10 seconds and then stops sometimes may start again for a few seconds before stopping completely, after that and or when driving the pump comes on about every 3 to 4 times I depress the brake pedal as pressure drops.
