Mid Grade Fuel
Irhmsd
I may be nuts, by my 2002 Limited seems to run much better on mid grade than premium. When I use premium, I often experience lumpy idle at traffic lights. Never seems to happen on mid grade. Anyone else have this happen?
I run 87 all of the time. Purrs like a kitten. I do run Chevron Techron fuel system cleaner every 3,000 miles to keep the fuel system clean. But my fuel grade is regular 87 unleaded.
On midgrade as opposed to premium? Or did you mean midgrade as opposed to regular? Try a tune-up. The 5VZ should be able to run smoothly on 87 octane.
You dont need to run premium but I see no reason that it would cause rough idle. Ive fully tuned out ecu's before and higher octane never causes an issue. Crazy.
Premium around here can vary from 91 to 93 depending on the station. Generally it's 87-89-93 in Jersey at most stations, but I see the occasional passing off 91 as premium. Used to love when Sunoco had Ultimate 94. Ran that in my 911 Turbo until they got rid of it.
In some areas like mine where I get bad fuel I run nothing but premium because it's the only one that doesn't get messed with.
I've never noticed a rough idle using 93, I have been using it sense day one and have always seen a improved fuel economy with using it. Kinda strange you getting a rough idle from it.
I was actually talking to my dad last week about this same thing. He is a Toyota Master Technician for the last 34 years. He said that 87 octane fuel is perfect for city/highway driving. Use 89 octane fuel for when you have a heavy load i.e. towing or full of cargo. As the cylinder/piston heats up under load you will need the higher octane fuel. He also said that is the primary function of the Knock sensor, to help keep the timing.
tuṣṭāva
