Mien4x4's Build
Sweet build and nice score on the parts. For the sake of possibly saving you some hassle. When installing the uca's make sure you put some grease between the bushing and outside washer. I failed to read that part of the install sheet and it started squeeking in a month. After R&r it's perfectly quite.
TBuzz
thanks for the heads up ill keep that in mind .
when you installed your ucas did it throw off your alignment by alot?
I don't know about that b/c I put them on in combination with my lift. It didn't noticeably drive worse after install. When I took it in I requested
4 degrees caster
0 camber
.04 total toe and got this
image-36.jpg~original
Looks like they could have done it and went right last the numbers. I'm going in tomorrow for another.:shrug:
a little update on my rig. i got it some new and used stuff for it
17x9 pro comp soft 8s steelies
and finally pick up and air compressor
got a pair of bump stops from the s10 blazer installed and tested
might have to trim a little bit of the bottom to gain an 1''-2'' of up travel back
finally broke my first cv at rairie city went to test some things out before the tral run on the 26th and at the same time broke my phone :ybrick: right after so no pics but this one
patnewton
