Miheckman's Build/Fix up Thread
miheckman
i got a 1996 Toyota 4runner base 5 speed 4x4... paid 1500 it had 145,000 mi now has 170,000
The to do list in the next few months
breaks
starter
tires
lower ball joints
the day i got her home
day1.jpg~original
The first thing i did was paint the front grill it was really bad
100_0369.jpg~original
i didn't like the gray so it went to black. i also did the front bumper.
IMG_20111002_113205.jpg~original
then i had to get a new set of rims.. i hated the ones that came on it
IMG_20120120_151134.jpg~original
then the guy i got it from put a head unit in it but it was old and didn't work so I got this one and it was a nightmare to put in (he cut the factory plug off.
IMG_20120201_160635.jpg~original
more to come.... stay tuned
Looking good, great deal.
I have pretty much the identical truck so I'm interested to see what you'll do to it. All I've got planned so far is the Tundra Brake upgrade (199mm).
"A spark plug shorted by excessive oil entering the combustion chamber is shown below. This is often caused by piston rings or cylinder walls that are badly worn. Oil may also be pulled into the chamber because of excessive clearance in the valve stem guides, or badly worn valve stem seals. If the PCV valve is plugged or inoperative, it can cause a buildup of crankcase pressure. This condition can force oil and oil vapors past the rings and valve guides into the combustion chamber."
I would start with replacing the PCV valve.
Also run 1/2 qt ATF in the engine oil for 100 miles then change the oil and filter. This will clean gunk out of the engine. Maybe clean the valve guides and loosen stuck piston rings.
I run restore Restore USA - Engine Restorer in my high mileage engines.
so this past weekend I got to do some work to my truck i re did the rear bumper i got new bumper ends from a member on this forum (thanks for the help)... i also got the rocker panels and front bumper rock guarded
so here are some pics of what i did
IMG_20120128_174358.jpg~original
IMG_20120128_174431.jpg~original
i had to do some cutting
IMG_20120127_183100.jpg~original
the final product
100_0522.jpg~original
100_0521.jpg~original
100_0520.jpg~original
Ambrose67
