MIL, TRAC, VSC and brake lights on 2002 T4R
t4r0209
I am seeing error codes C1246 master cylinder pressure sensor, C1223 ABS fault and C0210 RR wheel speed sensor. Any suggestions on where to start diagnosing the issue or how to check the sensors in question?
Visually check the ABS sensors, make sure the wire or plug didn't get broken off by a stick, rock etc... Also check the wheel bearings, they could go bad and ruin the ABS sensor. I'm no mechanic but these are the 2 situations that happened to me when my dash lit up like a Xmas tree.
Thanks off-road runner. The RR abs wire was broken, shock mount broke and took out the wire, a little solder and heat shrink and the problem is fixed...replaced the shock too!
workingwheelswnc
