Mini Morimoto RetroQuik Bi-Xenon Projector Swap for '06+ Headlamps
No, 80mm would be too small...the one I used is 90mm. It just fits around the shroud perfectly. Now I have to figure out how to power it as a DRL and turn signal. Our 4Runners use the turn signal bulb as a DRL also. I would rather use the halo as the DRL...it is nice and bright, and use the turn signal bulb as a side marker light only when headlights are on.. I'm working on a solution.
Did you ever figure out a wiring solution? I'm picking up a set of the Triton v6 switchbacks from vled to use in conjunction with the halos as DRl and turn signals.
Yes, I have my lights working properly. Read my posts, #125... I was able to use the Halos as DRL and can switch them off at will. They also operate as turn signals, turning amber when the signal is activated.
South-O 4RnR, If you need a factory wiring diagram, let me know. I can print them out and you can stop by the shop and get them if you like.
Sent from my iPhone using Tapatalk Pro
Lightwerkz recently released mounting brackets to fit the better performing Mini D2S 4.0 / G5 type projectors https://www.lightwerkz.net/index.ph...6-2007-2008-2009-toyota-4runner-brackets.html With a little grinding you can even fit the larger G5-EXL projectors,which currently have the most intense hot spot and high beam
$70 for a set of brackets...yowza. With that said, I used the generic mounting brackets from TRS and had to cut them and drill the mounting holes. After doing this and not getting "perfect" results, I wouldn't hesitate to pay the $70.
yea, the bracket method are good for the diyers thatdont want to spend alot, but the results are pretty good.
i prefer to use oem now, my oem rx projectors lasted me for 6 plus years now. its still good, but it can use a whole new headlight lens and a tuned shield.
i just took put the s2k retros on and it was really bright with 50w and used cbi bulbs i had laying around.
they all say the rx afr can use a shield tuned/ drop and itll be the same performance of the s2k.
<blockquote class="imgur-embed-pub" lang="en" data-id="a/1M1Ty"><a href="//imgur.com/1M1Ty"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
Glad to see this thread is still going strong.
Did you tune your rx projectors? I just put some in my new Taco and need to tune but not sure how.
my rx330 has only the tsxr clear lens, and the squirrel finders covered up.
a shield drop with those could of help.
on another car i got the rx350 afs, its on a 2011 camry, that has the clear lens on and its tuned from the lens, looks pretty bright with 50w on osram svs.
which RX projector is installed on the taco?
https://www.hidplanet.com/forums/fo...-swaps-color-mods/52440-rx350-with-sti-r-lens
Rx350 with clear lens, output is okay but cut off is terrible. I got some paper spacers to add but not sure what else is involved.
Well the thread say use the paper spacer on the lens holder. Then put the clear lens and use the tab to secure the lens. I also read that to use washer spacer on the nubs. Tuning the projector requires atleast 40ft of distance. Remember don't go too crazy with the blue cutoff.
Any pics of your S2K setup/install? Im about to redo mine as I only had them temporarily mounted for a short time. Actually took them off months ago and have yet to go back and finish it. Been focused on my audio instead. Lol.
Ive already dremeled the hell out of the housings to flush up the projectors. Mainly ive got to tune my cutoff and center the lens visually in the factory bezel opening. Running the E30 clears too. Cant wait to get it back on.
i had lightwerkz do mines, i just dont have the time and patience for the retro.
the lights looking good so far. i will need to tweak it some more on the alignment.
i spend alot of money on these new retros. new oem housing and the cost of the retros is around 1500
i know my audio is alot too, so much involved :D
go back a page and see how they mounted.
No shame in that. They do great work! Sure its expensive but quality costs and should last forever. Ive been sucked back down the rabit hole of car audio again too, thanks DIYMA. Lol
Sent from my SM-G900V using Tapatalk
What did they charge you for labour?
Hate to revive such an old thread, But does anyone have a stock 06-09 projector bracket/shield that they can scan to a PDF and post or email?
I'm Planning to retro mine, and want to fabricate the brackets to my new projectors beforehand.
youngrk
