For anyone with kdss. Unbolt the sway bar bracket (2 bolts) for the side you are currently working on with both sides in the air. When you finish with one side wrestle that bracket back on with ratchet straps and large cable ties BEFORE you start the other side. Wasted the rest of my day fighting myself.
Anyways. I’ll get back to it in the morning. Need to tend to my body for now.
Using a bottle jack under the KDSS piston much easier than the ratchet straps, for the next time of course. Glad you got it figured out!
Glad you got it all back together. Last time I did mine I read somewhere that putting it in 4L disables the kdss and makes it a lot easier to handle. I dunno if it actually worked or not but it sure as hell seemed like it was a lot easier to manhandle back into place than the first two times I tore it apart. I hope you dont have to do it again but just a heads up!
Told ya you're going to get faster! LolEverything is back together. Amazing how fast you get when you do it a bizzilion times.
rig looks good man. My Bilstein 6112/5160 & T13 setup is lower than that.
How much height did you lose? Once you scrub it after install they really shouldn't lose any height at all (hopefully).
