I kind of miss the Torsen center locking feature on my 4th SE, kept it from binding up on dry pavement, it was like having a AWD feature and the best of both worlds.
I'm going to refrain from being extremely sarcastic in my post because I'm feeling nice today.
This has been discussed over and over again. There are a number of threads that talk about the lack of a torsen center diff in the TE and SR5. I can't, for the life of me, think of why you need AWD on dry pavement in a 4600lb SUV w/ 265 series tires. Also, the locking feature on the torsen center diff would actually make you bind up on dry pavement as it would make the front and rear prop shafts spin at the same speed. I think you meant "I kind of miss the Torsen center differential feature on my....."
Yes, having 2H, 4H (unlocked), 4H (locked), 4L (unlocked), and 4L (locked) modes for the transfer case would be nice, but personally, I wouldn't pay the extra money for it if it were an option. FT4WD is available on the Limited.
Quentin, you never know when you need 4WD..
This is where that little stick to the right of the gear shift comes in a mite handy. :hello:Quentin, you never know when you need 4WD..
My FWD GTI made it through those situations with no problem; I don't see why my 4Runner would be any different.
Ha, I know you know better than this! FWD vs RWD! BIG differences in how it handles in the snow, pulling vs pushing. If you HAD to pick one over the other for the snow (no 4WD involved) the FWD would be your best bet.
My last SUV had FT & PT 4WD, and I will say the FT was a nice feature, as others have said, but I knew it was not a deal breaker for me in the 4R, besides if I really wanted it I would have paid the extra for the LE. My 99' Durango had the 5.9L and seemed HEAVY in the front and light in the back, it also had a ton of low end torque. So, when trying to pull out on streets with rain or light snow hitting the gas would instantly break the back end lose, just sit and spin, that it even had a LSD in the rear. It allowed me to put it in FT 4WD and not worry about it if I was in stop light hell.
I'd probably be alright in a Miata w/ decent tires in most cases. :lol:
Adding an AWD case should be very doable, but it will cost anywhere from $1500 to $3000+ depending on what is involved and if one is using a new case from Toyota. I converted my 08 Tundra to the AWD case from a 200 Series Land Cruiser. If my wife buys an automatic equipped 5th gen 4R or FJC, I will likely be converting it AWD.
Oh, you had to go there! Wife came up to the north with a Miata (6 speed), I do not care what you have for tires (we tried) that thing does NOT move in the snow! It worked better when I tossed 200 lbs of sand bags in the back though. Needless to say she now has an Escape Limited for the snow.
