I should change the name of my build threat to the "Don't Go Full Retard" thread, haha.
So ever since my trip and overheat I have had the smell of burning oil. I know my valve covers are leaking now and I have tightened the nuts down in the various areas. I replaced the radiator already and checked the oil, no issues there. I had a different
thread where I was asking about what I should do about my issue. The burning oil, poor MPGs and lack of power compared to my friends runner which is the same (same armor/tires/gears) I have decided to do what I termed an engine re-fresh. I also have a grinding sound in my transfer case so that is getting replaced at the same time. Here is what I mentioned in my other thread, it is what I plan on doing as of today.
So here is my plan:
- Remove Engine and transfer case. I need to double check but I am going to separate the transfer case, then pull the engine/trans together. Then splint the engine and trans once out.
- Put engine on stand, remove intake, timing cover, timing belt, water pump, then remove the valve covers followed by the heads.
- Take heads to Engine Shop for re-build. Then while I am waiting I will clean out all the old oil/grease/dirt that is all over my engine bay.
- Once they are done I will reinstall the re-built heads. Followed by water pump, timing belt, valve covers and rear main seal.
- Then do any other random stuff I need. I want to put new plugs in for good measure. Plug wires are only a year old so those will stay. PCV is also a year old so that will stay.
- Then I will re-install the engine/trans/transfer case.
- Last is new hoses and belts. I also think I am going to get some synthetic vacuum hose and replace the vacuum hoses in the engine bay. I noticed I have a number that appear cracked and old so I just want to get that sorted out. (anyone know what size hose I need?)
All my suspension stuff will be on hold until I get this done. We also are buying a house and will be moving so my fab/suspension stuff will be on hold until Aug more than likely. I can this the "full-retard" thread now because what I have purchased with suspension and now what I am doing with the engine... I just can't seem to stop dumping money into this thing. Which is honestly fine because I have grown to love and appreciate it again after getting a little annoyed with it previously. Ya I would say it is safe to say that I will never get the money back I have put into this thing. But it is a great truck and once this stuff is done I am hoping I can just put miles and oil changes on it for a little while... well until I decide I can't live without a super charger haha. We will see where this goes. It has a lot of various things going on and I feel all over the place with it. But I have a vision of what I want and I feel like I am slowly getting closer...
