Monster 4Runners (Monst4rs)
IMG_0643.jpg~original
I really love the color of those flares! What did you use to paint those fender flares? I have been looking into painting them for a while.
Your info says NM, but that sure looks a lot like white knuckle in Moab. .
I will have to check the thread because that is absolutely white knuckle in Moab. I have also wheeled a lot of las cruses, NM as well as all over Az which is home for me:)
I said NM I meant AZ. But I have wheeled White Knuckle and going down it live up to the name.
My 00 4unner
37's 1-tons and more little mods than you can shake a stick at!
Sorry I'm just getting to this. Haven't been on in forever. I don't know the code but, its the same color used on the trim around the license plate
not a huge 4runner but getting there.
Sitting on 35's
need help
I drove my 2014 4runner off road, and while doing so, I accidently drove a large rock that got stuck behind my left lower control arm. I put the car in reverse and forced it over the rock. Now my steering column appears to be shifted to the left ( not sure if it was like that before), and on inspecting the bottom, the LCA is scraped, and the brackets where the LCA inserts in the frame is bent. The left front wheel is now 5mm ahead of the right one. Alignment is within specs. what could have happened to the steering column and to the left wheel?
