More 265/75/16 rubbing issues!
3rdGenJeff
I have a 97 sr5 w 2.5 OME lift + OME shocks and Rear tires rub wheel wells (outer w no flares) under moderate articulation. Running BFG AT 265/75/16s. Best solution??
Your back tires are rubbing? That's weird, are your wheels stock? Do you have wheel spacers?
I had the same size tire without a lift and it didn't rub in the back whatsoever...
im calling BS on this and think this is a troll, his pic album goes no where, im running 285s with no lift and not rubbing in the rear. so how does someone with a 2.5" lift and smaller ie stock tires rub? its BS the op is not and op but rather a troll
I'm guessing one or more of these are causing your issue.
Wide wheel spacers.
Small backspacing on the wheels.
Wide wheels.
No panhard bar drop.
Adjustable panhard bar set too long.
Is it rubbing on both sides or only one?
Which side?
What is your wheel/spacer setup?
That is a really lame troll if it is...
I have the same size tires, and a shorter lift, and I don't rub the rears at all. I rub the fronts, but that's it.
I do have over 5" of lift in the back of mine but my Yokohama AT-S are bigger than the BFGs. I can flex either side till it lightly rubs the top of the inner fender. I'm running stock wheels with 1.25" spacers.
REE
