Morimoto XB headlights on limited
amir_gh
Just finished putting these on. Looks awesome
Sent from my SM-N975U using Tapatalk
I might splurge on a set of these in the spring. They are $1590 cad plus tax if I get them from ProLightz out of Gatineau, Quebec.
Could you check if your DRL strip flickers/dims when you press firmly on the brakes? I just noticed this with my set in my garage this morning. Only happened when I press firmly on the brakes. I can see it just by looking at the ambient light against the wall in my garage when the DRLs are on.
I will check it. What year is yours? Do you have any aftermarket stereo system? What was the last time you replaced your battery?
I would appreciate it.
2018, yes I have sub and amp and a winch, battery is just fine. The sub was barely on when I tested this, AND they don’t dim at all when the radio is cranked. I have no idea why this dimming and the brakes being pushed firmly would be a thing. I’m pretty stumped. It’s just the DRL bar, not the headlights.
Do you have the fuse tap harness installed?
No problem. Check this one too
Apparently you need those good AGM batteries. Something higher than 800 CCA
I wonder why though? I’ll have to check voltages to see what is going on. My battery has never given me an issue at all.
EDIT: after reading the threads, it seems like many have a similar issue. It also seems like many couldn’t fix it. I know it is related to the brake booster engaging since it only happens when the vehicle is running. A battery upgrade may be in my future.
Sorry for the thread jack. Your runner looks great!
