Mounting Baja Designs LP6 to stock bumper
Will_4R
Member
Does anyone have a solution for mounting BD LP6s to a stock bumper? Does anyone make a bar with brackets that fit through the plastic bumper?
Been in touch with Rago and I was informed by them that there universal mounts and light mount will work behind the 2020 4runner. I plan on putting 2bajadesigns LP6’s back there.
Wouldn’t you rather mount them in front the of the bumper instead of behind it? Take advantage of the side lighting on the LP6s, and also not have the grill block or distort some of the forward light?
Not really I don’t want anything mounted into the bumper. And also these lights are so bright not sure if I’m doing LP6 or LP9’s. The grille will not effect the light output. I had a Cali led bar behind my 15 Tacoma. And what a difference. No noticeable effect from the grille. The Bajadesign lights will blow away the led bar. Even on Rago web site they have them mounted behind the grille. Also the 2020 Pro’s or 4runners have that safety sense which this is the way to get around it.
Bunkstaff
