Mounting Custom Sub Box
T4RNightHawk
Hey guys I finished my custom sub box last night and was wondering how y'all that have custom boxes mounted yours. I was thinking L brackets but I'd also like to secure the top.
Also would there be any problems with mounting the amp on the side of the box. I had problems with resistors rattling of my crossovers when they were mounted on the box so I'm wary of doing that with the amp.
yeah, going to need more info.
Here is my custom box i made.
It's like the same as the one above
This is the best picture I have. I'm in school right now its essentially an L with an angled piece next to the wheel well.
i used L brackets to mount mine. honestly velcro might do a decent job holding parts of it if you don't want to drill
IMG_0802.jpg~original
IMG_0801.jpg~original
I made a bracket on the front of mine that bolted to the place where the tie down was located on the floor. Then I made a bracket that screwed to the back of the box that bolted to the wall where the bungie tie down was located. You can see it partially on the top. That pulls out and has a square hole. Perfect for a carraige bolt. Hope that helps.
I ended up mounting it to the old tie down location for now. I still need to make a bracket for the top. I'll post pics later.
