paddlenbike
Member
"Oxygen sensors (O2) used in most of today's automotive gasoline engines are failing at an ever increasing rate. There can be one to five sensors per vehicles and having them replaced can cost a consumer $100.00 to over $300.00 each. This can happen in brand new vehicles with low mileage or older high mileage ones.
Interestingly, most of these "failed" sensors are not actually defective or even worn out. What has happened, is that a small amount Ethanol in the gasoline (gasohol) will get past the piston rings and into the motor oil. The Ethanol with agitation and heat liberates some of the phosphorus from the motor oil. This phosphorus is vaporized and sucked into the Positive Crankcase Ventilation (PCV) system and burned in the combustion chamber. This burned phosphorus on its way out the exhaust coats the O2 sensor(s) building up in layers.
This phosphorus coating acts as a insulation causing the sensor to react slower than normal. The engine computer reads this slow reaction time as a failure of the sensor forcing its replacement.
Note: This is the same material that coats catalytic converters causing them to go "cold" or cease to function."
Tell your legislators you want ethanol removed from our fuels. It is degrading our car's fuel systems and reducing life from our vehicles, reduces power and economy, and the quick degradation of oxygen sensors and catalytic converters harms the very thing it is intended to help, air quality.
