MTD's "The Hulk" Build - Narrated by Morgan Freeman
MTD
MTD's "ForeRunner" Build - Narrated by Morgan Freeman
MTD's The Hulk
1999 Toyota 4Runner
Imperial Jade
This build stems from the sale of my 05' Tacoma to pay for school among other things. The Runner was at one time my Dad's who picked it up from an older women in Michigan. She kept it very clean. It will never be the same again..... The plan is to build a capable overland vehicle, just enough to get my girlfriend (soon to be fiance) and I to where we want to go. It's going to be a long ride so please enjoy!
Current Photo
IMG_6155+%2528800x533%2529.jpg~original
Mods List:
Lighting:
FX-R Retrofit Kit 55W with Apollo Shrouds
4X China 18W LED Lights
Homebrew Light Bar
Depo Clear Marker Lights
18W China LED Reverse Light
Custom Revers Light Braket (works with hatch open)
LED Dome lights
COB LED Map Lights (Super bright)
35W 3000K HID Blazer Fog Lights
120W 22 in LED Spot Light Bar
120W 22 in LED Flood Light Bar
Rigid Industries LED Lightbar Mounting Brackets
Fog Light Anytime
55W Hella 700FF
Suspension:
Rough Country Nitro Rear Shocks
Rough Country Nitro Front Struts
OME 880 Front Springs
OME 906 Rear Springs
OME 881 Front Springs
OME 891 Rear Springs
Icon Coilovers
Electronics:
Sony XAV601BT Headunit
Alpine SWE-12S4 12 Inch Sub
GB SPST Rocker Switches
12V Socket Behind Dash (permanent phone charger)
Zune - Permanent Mount
Ultra Gauge
Midland 13-882B CB (1975)
Blue Sea Systems 5029 12 circuit Fuse Block
50 Amp Circuit Breaker
Wilson 2 ft. Black Fiberglass Antenna
Blue Sea systems 5028 6 Circuit Fuse Block
Kenwood KSC-SW11 Compact Subwoofer
Performance:
ISR Mod
Interior:
Weather Tech Digital Fit Floor Mats
Exterior:
Dee Zee Mud Flaps
CBI Antenna Mount
Armor:
4xInnovations Front Bumper
RAT Products Full Coverage Skid Plates
4xInnovations Rear Tire Carrier Bumper
4xInnovations Sliders
Recovery:
XRC8 Comp Winch
20k Snatch Block
20K Tree Saver
Walmart strap :(
2x 3/4 Shackles
Wheels and Tires:
Painted Stock Alloys
General Grabber AT2 LT265/75/R16
Overland Gear:
Tepui Autana Roof Top Tent
Custom Built Storage/Battery Box
Blue Sea Systems Dual Battery System with Odyssey 31M AGM Battery
5050 LED RTT Tent Lights
The beginning:
I can't find any bone stock pictures of the truck so we are starting at the first mod which was my 55w FX-R retrofit. Notice there are no corner lamps? The oven got a little too warm while I was putting them back togther after painting :P
mtd-albums-mtd-s+green+turd+build-picture22278-965300-10151571882527621-1909387606-o.jpg~original
Next came the sound system, this Sony headunit is probably the best one I have put into any of my vehicles. The Alpine subwoofer and amp are great too, you can really tell what quality gives you.
The Chinese 18W led spot lights, they worked pretty good for what i had paid for them. I think I picked them up for a little over $80 from a kmotoring on ebay. The "light bar" they are on was just an aluminum tube from FleetFarm and a pair of coner braces cut down so that they sat lower on the bumper the total with hardware came to like $15.50 or something like that. :whoo:
mtd-albums-mtd-s+green+turd+build-picture19617-20130602-171708.jpg~original
mtd-albums-mtd-s+green+turd+build-picture19619-20130613-173902%5B1%5D.jpg~original
mtd-albums-mtd-s+green+turd+build-picture22331-img-20131012-202353.jpg~original
Got new Depo conners to replace the ones I melted. :happens:
mtd-albums-mtd-s+green+turd+build-picture22324-7106-10151590985237621-1558392697-n.jpg~original
mtd-albums-mtd-s+green+turd+build-picture22326-969589-10151598591527621-127551003-n.jpg~original
Next came my OME lift Rough Country shocks. I did all the work myself in the parking lot seen in most of my pictures. If I had to do it again I would have went with Bilstien 5100's versus the RC struts, but the rears I would not have changed at all they are great. Note that there is not much noticeable lift because 880 and 906 springs were used.
Apparently this is the only picture I have after the lift...
mtd-albums-mtd-s+green+turd+build-picture22330-20130928-145318.jpg~original
I couldn't see what I was doing when loading/unloading the boat for bow fishing so I made my self a mount and got an 18W Chinese led flood. This sucker is bright! I also really like it because my mount that I fabricated, allows me to use the hatch and have the light still be effective.
IMG_20131121_220921_984.jpg~original
IMG_20131121_220948_205.jpg~original
Next came the HID's in the stock fog housings. I read several threads that told me that it was impossible to do it so that the housings would be water tight after the conversion, I deiced to prove them wrong. You can look at my write up here:
http://www.toyota-4runner.org/3rd-gen-t4rs/146978-[how-]-sealed-hid-factory-fog-lights.html
mtd-albums-hid++stock+fogs-picture20175-20130722-230446.jpg~original
mtd-albums-hid++stock+fogs-picture20107-20130722-231717%5B1%5D.jpg~original
mtd-albums-hid++stock+fogs-picture22332-20130830-194814.jpg~original
I painted my wheels to match my headlights. A lot of time with prep and paint and did a 2 part clear on them the look sharp!
Then my younger brother didn't look back while backing up and it was time for a new bumper. :D The best picture I have of before the bumper replacement was this one next to a super clean 4th gen.
Ran through several colors on photoshop before I settled on the last one :)
Went up to 4xInnovations and hung out with Adam and Ben for a while, a week later I was back up there and we were working on this. I went with the full hoops in the hope of keeping my retrofit in one piece.
I must say though, 4x does a great job with their products and would definitely recommend them! Plus their parts generally look awesome!
Got it all painted and the 4inch round fog lights installed. I also took just a little time to convert the lights to HID for that added punch. Halogen just doesn't cut it ;)
I also had got my new tires, General Grabber AT2's, the same weekend. The shop that put them on though deiced that I would be ok to just destroy the paint on my wheels when they did it. The tires are great though and have a pretty aggressive tread pattern.
I got my LED Light bar with the improved lenses from China then, It looked sweet and was super excited to get it on the truck. Unfortunately when I powered it up I got a nasty surprise. They are sending replacement parts to fix it and since I have alot of experience with LED systems for my bowfishing boat I can do it. It just stinks I couldn't put it on right away...
I got my tube mounts so I said screw it and put it on with the three burnt out. No sense In not using it if it works... Some output pics are bellow, keep in mind they were taken with a camera phone so they are not the best.
Low beam only
Low beam + led light bar
Got some Weather Tech floor mats yesterday :D Just in time for winter too, I had just began to snow as I was putting this puppies in.
Removed the 906 springs to put into my dads 97 T4R so he can pull his boat... I got a set of 891's to replace them though :party:
Got my replacement light bar for my favorite price :cool:
Fab'ed up a quick bracket out of a 1 in aluminum flat bar :becky:
See post for output pics!
Installed the Midland CB radio that my dad gave me. It is really great I love the vintage look but it is old so It will end up being replaced by a new more powerful modern unit.
As funny as it is I think the fuse block is one of my favorite mods yet. It really cleans up the engine bay and simplifies any future wiring. It is really nice to be able to have all the fuses in one place as well and if needed I can shut off all the accessories attached to it. I used 4 GA battery wire with solder on terminal nuts so that I could get the exact length that I needed.
[MENTION=94545]MTD[/MENTION] [MENTION=84681]white_n_slow[/MENTION] Morgan Freeman could narrate my morning shits and make them sound epic.
Ooooh. Ahhhhh. :lol:
I am excited. Just read this sentence you posted in a Morgan Freeman voice.. :D
Best sig EVAR
lol, why don't you wait until you're not so strapped for time to start the thread :p
Sent you a PM several days ago and didn't hear back. Did you get it?
images
Worst build thread ever!
Updated for the most part!
Seriously though it is just a duplicolor spray bomb from farm and fleet. I think it was called just like graphite. Its a dark gray with metal flake. I did everything in it so far including my headlights and wheels.
Hope it holds up for you. I had mine powder coated with semi-gloss black. They had a color that was similar to a bare metal color, can't recall the name of it. It looks like the color you used. I considered that color as well. I am happy with the black color.
