Multi mode control switch
dkovac said:
if they have the same drivetrain wold it be possible to go the other way? a V8 with 2wd?
The part # of the V8 t-case is different than the V6. They are both the same 'series' but they are a bit different. Without looking it up again it's something like xxx-xxxx-xx-A vs. xxx-xxxx-xx-B. I would have to assume the mechanism that allows 2wd is missing in the V8's t-case.
:cheers:
:cheers:
So they are not the same
Mike07SE said:
Doesn't it come down to something fairly simple like it being the acuator?
An actuator disconnect the front and mechanically lock for the diff should do it.
:cheers:
turbomikee
