juiceboxer
Well if you want to get technical all anyone needs is a phillips and flathead screwdriver and an adjustable wrench (cringe). It looks like a medium sized set from any local store is what you need.
juiceboxer said:Well if you want to get technical all anyone needs is a phillips and flathead screwdriver and an adjustable wrench (cringe). It looks like a medium sized set from any local store is what you need.
juiceboxer said:and a GOOD floor jack, you don't want to be under a 2 ton truck when your jack fails.
Come to the "Dark Side" Runnerup...I know you want too.and word to the wise... dont use wd-40 to lubricate ANYTHING on your truck... only use it for what it was designed for, and that is not a long time lube.
IntoTheVoid said:Come to the "Dark Side" Runnerup...I know you want too.
The vinyl strip on my rear bumper was faded so I hit it with some WD-40...Before and after photo below.
I also brush my teeth with the stuff. :biggrin2:
