My $5 mod in 5 mins.
T4R.org has helped me in so many ways, I am really thankful for this board. I had recently made a thread about things I wish Toyota would change in the 4Runner and one of the take aways is an automatic way to change the ambient lighting by adding a light sensor to the non-TRD Pro/Limited trucks. A user on here posted a link to the ebay sale that had the sensor for $5 vs. $100 at the dealer. The item took 5 weeks to come in and granted it doesn't have at Toyota stamp on it, it is identical.
does this sensor work when the headlight is on or off or both? thanks!
so does this switches the navigation / Buttons from light to dark mode ???
cuz I think my 2014 Trail Premium has this
Worked on my 2019 off-road premium. Surprised that Toyota went through the trouble of connecting the harness to a dummy.
Installed my $8 sensor from Kentucky yesterday, install literally took 30 seconds. I spent the most time ensuring that I had the connector pins lined up correctly and then snap. Do you have to enable night mode on the GPS? Any other settings I need to enable?
as long as the thumb wheel on the left side of the steering wheel isn't on max brightness, it will auto switch from day and night. If it is on max brightness, that will override everything.
OK, that would be my issue. I was playing with it this morning but I have the max brightness on at all times, thanks!
I didn't have my hopes too high but confirmed my 2013 Trail isn't wired for it. (even though it shows up on parts diagrams for my year)
That's crazy that Toyota left that ability off. My Limited has the light sensor and in auto mode it's annoying driving under bridges during the day with the nav going from day to night mode and back. I'll have to pay attention to the interior lights
Installed mine tonight. 2018 ORP. Works great... Fixed one of only a few complaints about the 4runner.
Sent from my Pixel 2 using Tapatalk
Just to clarify:
This sensor will enable your dash lights and Entune screen to dim at night without you having to fiddle with the light control thumbwheel (located left of the steering wheel).
It does not dim or turn on your headlights.
The way I use it is to set the thumbwheel to max brightness without clicking it to the highest override setting and leave it there all the time. Check out how this functions at night (or in a dark garage) by turning the ignition ON but do not start it. Turn ON the head lights or parking lights. Your dash lights are now dim in “night mode”. Take a flashlight and shine it closely on the sensor. In two to three seconds the dash lights brighten to “day mode”. Take the flashlight away and they dim again to”night mode”. Yay.
Now to set up your Entune screen hit the Home button, hit the gear symbol in the upper right corner, (should now be in Setup menu), hit Display. As long as your headlights are still ON you’ll see the “Adjust Contrast/Brightness” menu with a “Day Mode” and checkbox. Deselect the checkbox.
Now hit the General button and with headlights (or parking lights) still ON adjust the brightness and contrast to how you like the Entune screen to look at night. Hit the OK button to save the settings.
Now you’re back at the Adust Contrast/Brightness menu again. Turn OFF the headlights and everything get bright. You are now in “Day Mode”. Hit the General button and adjust contrast and brightness to your favorite daylight settings. Hit OK to Save.
Back out of the menu and get to the Navigation screen (showing a map). With headlights OFF your dash and navigation screen are bright in Day Mode. Turn the headlights ON and everything dims to Night Mode and the nav screen goes to the dark background with white text.
With headlights ON shine your flashlight on the sensor and watch the dash and Nav screen go bright in Day Mode. Take away the light and it dims. Eureka!
Now you may be wondering what the “Day Mode” checkbox does. That’s for a third contrast/brightness setting for the Entune screen. If you were driving in the day and suddenly it starts raining and you want your headlights ON, the dash and Entune screen would also dim. Which you probably don’t want, you want normal Day Mode brightness. So you have this option to drill into the menu to get to this screen and check the box to force the screen to stay bright even if lights are ON. While you are driving. Right. A pretty useless feature since you can just click the thumbwheel to max position and it’ll do the same thing.
Or if it doesn’t get too dark during the storm, the light sensor module will keep you in Day Mode anyway. No driver intervention needed!
What's the trick to pop off the dummy cap?
Is it possible to release from underneath after removing the screen?
I tried to pry up the cap but felt like I was going to leave unwanted marks/scratches. Would rather take the longer route if it means not having any unwanted scratches on my dash.
Thanks!
Stupidly, I slightly scratched the dash next to the plug from using an identical pry tool as the OP. The material on the dash is pretty soft and easy to scratch. I recommend putting something down next to the plug when you go to pry it off.
I also noticed you have a 2015 Canadian SR5P...as do I (even though I'm in CA). I popped the plug out and saw the 3 wires to the blank plug and instantly purchased the sensor on Ebay. Do you mind confirming it works with your Canadian 2015 SR5P once you install? Thanks a bunch!
Didn't even use a pry tool, got an old credit card, use finger & nail to lift either side of the dummy just to get it off the surface a bit, slid in the card and used the card to wiggle the dummy out.
Thanks!
With that kind of stuff, I normally lay down 4-5 layers of painter's tape around the area I'm fiddling with to prevent scratching. If I scratch the area underneath, I'm ok with that since it's out of eye sight.
Do your fingernails look like this?
AndiGarage
