My 98 Limited
Installed this and the 2 wires for the power switch is mind boggling.
sent from my Hawn fingers
Do you happen to have the operating manual for this? Got mine installed but I think my compass needs to be adjusted but can't find the manual online. Only found the install manual.
Sent from my SM-N910V using Tapatalk
You work fast!!!!!!
I wired the 4 wires the day before and my whole R Front side was out because I installed the door mirror housing. Plus I don't work! Lol
What Chim said below
If you scroll down on this thread link there are some images of the manual to help you adjust the compass and how to use the unit :)
Hilux Surf Field Monitor installed in a 3rd Gen Write-Up *PICS* - YotaTech Forums
Listen to him!
Great looking truck man. Always liked them in darker colors, black is fantastic.
Much Mahaloz. I really don't like dark colors for car because you can see everything (dents, dirty, etc), but it grew on me. Funny thing is I had 2 dark trucks since I moved to WA. Gotta be the water. Lol.
I mounted my temp sensor under my R Headlamp. It's in the factory clip hole and I drilled 2 holes for a zip tie to hold it down for stability. Hope it works well. Much Mahaloz [MENTION=124101]Chim[/MENTION] for making me spend all that money.
So I've been working on my 3 din console here and there. This is really like playing TETRIS. I just did the extension sides for the 3 din part. I might do the bottom half custom and take out the Tacoma shifter console and go back to the stock 1 to make it clean. This means I'll be losing 4 cup holders 1 crack, but I will be ordering the 2 side cup holders they make for our 4runners.
Made a hybrid switch panel above the HVAC controls. Left - Middle is US spec and the Right side is JDM coin slot
My LEDs came in the mail yesterday and I installed it today. I ordered 3WLED-NWHP5: Natural White &
574-CWHP3: Cool White. I ordered the wrong color for my cluster, so I just ordered another 3 of the cool white and more of the 74s. Also installed some LEDs in my FMU.
Well installed my JDM hybrid console for giggles. Still need to fill in the gaps. The guy at the store told me that bondo doesn't work with plastic. [MENTION=30949]SIKHILUXSURF[/MENTION] what did you use? Please let me know. Mahaloz in advance
44fc415719d7c9d0bc2e2c9c788bb4b2.jpg~original
5ab13c3751006b9b892e2ca1868da2af.jpg~original
b24499365ff8b470aed584bf12a4703a.jpg~original
i used a 2 part epoxy i got from a friend that works at a body shop its practically like a plastic weld deal. im sure there is something out there. i would never use bondo on the console since it will flex and ultimately crack.
P.S. your ac controls look to be evenly lit and not yellowish white in them. did you modify anything?
Here are afew pictures of my console during the process of making it.
5D60B55B-53EF-475A-A423-125954D9FCF6.jpg~original
02AC52D1-876B-41CF-B026-365E646C2B69.jpg~original
A2815934-077D-4BAF-ADF9-2D315792F4EC.jpg~original
B912BA19-BF38-467C-A4DD-C6DF9E750E72.jpg~original
F200C10A-0C51-4BF1-9CEF-D9BE636BD1C0.jpg~original
4BE2E343-C85C-457A-9B42-16FC1709B664.jpg~original
21393B23-CE51-4053-BAE4-18A3D3A3525B.jpg~original
19A57FF2-49A4-486D-934D-217699BEA2AF.jpg~original
3B8969C1-A967-4676-98E8-19632C3531CB.jpg~original
8AD84837-80FE-4E4B-BADD-3E3A4BC36A5D.jpg~original
5958FED4-57A0-48D5-AD79-BD9F6DEA4A36.jpg~original
[MENTION=105773]busmup808[/MENTION]
where'd you get that CARBON FIBER gauge cluster surround, shifter surround ETC????
I think JB weld makes a plastic weld that may be worth looking into.. that's what I was going to do when I did my bezel.
PRWhite
