My 98 Limited
Actually I only tested the front out 2 weeks ago. Got the front from CL 1 month ago for $100 off the regular price and I didn't even have to pay for shipping. I guess I'm going to put a long travel kit up front
And yes I made those marks. It looked New when I got it
where did you get the 3rd row seat at? Does it fit without any mods?
I used a 2nd row seat from a Suzuki sidekick. Only mods you will have to do was drill the holes to be bolted down and I used Toyota lap belts from a 80 Series Landcruiser.
I just spent $700 dollars on my rear brakes. Bought Genuine Toyota bearings, keepers, ABS rings, Inner/outer seals. Damn that was $400. Then I went to Autozone and bought drums, cylinders, shoes, and a lot of brake cleaner (6). Spent $200 there. Last was paying Gregs Import Auto $100 for installation of all the Genuine Toyota Parts on the Axle.
Labor of Love for my damn truck. My body iz hurting right now. Gude night everyone. Aloha from Washington
Bought this at the Puyallup 4x4 Swap Meet last month and I for got to post it. It's the Telawei 4x4 Exhaust Jack
Also bought these TRED off my friend [MENTION=63487]A.Wilson013[/MENTION]
Was getting the vibes/no vibes when pressing the gas peddle and letting it go in high speeds. The famous ujoint special. It was a ***** to get off and a breeze going on and that's only the rear 1 by the 3rd member. Going to change the 2 on the front driveshaft when I fix the leaking oil seal on the t-case
Got threw fixing the front seals on the tcase and doing more maintenance on the truck. Now I go under the hood to change oil filter, plugs and wires using Genuine Toyota parts. My truck is literally coming up on 300K miles, so all this maintenance is good for my truck to keep on ticking. Next will be my timing belt and water pump in the next month. Will also be changing to a Genuine Toyota Radiator the same time. Bought the truck with an aftermarket one already installed just before purchasing it in 2014
You think my filter needed to be changed? It had a K&N filter and I went with Genuine Toyota one. Wow big difference
If you read my build, most of my parts is from the junkyard by my house. I just scored seat covers made by WET OKOLES Hawaii for $5. I have Scion TC seats in my truck and the covers I got are from a 04 Nissan 350Z. Yes these covers are for a Z and it fits like a glove on my TC seats. I'm a more functional kind of guy and I'm not entering a car show, so the rips don't bother me. Rather not have mud/grease on my seats. I can always clean with a microfiber towel and Dawn to make them nice again.
FOOTWELL WATER TANK - BY FRONT RUNNER
This came in yesterday afternoon. Here's the info:
This cleverly designed 40l (10.6gal) tank is extremely strong and is shaped to sit on the vehicle's floor behind the front seats.
Made from food grade polyethylene and is BPA free.
The cutout spans the transmission tunnel and the top section can be used as a nonslip floor or stacking supplies/luggage on top of.
This design allows for fitment into most vehicles.* Please check specs to confirm correct fitment before purchase.
If children are to be seated in the rear, the tank can be strapped to the front seat mounts using normal ratchet tie down straps.
The tank has plastic pipe fittings on each side for connection of a hose and tap. (Hose kits and taps are not included)
The Water Tank Hose Kit - by Front Runner are sold seperately.
SPECS:
Material used:
Tank: BPA-free polyethylene
Fittings: Plastic
Capacity:
40l (10.6gal)
Product Dimensions:
W 1200mm (47.2") x H 180mm (7.1") x L 250mm (9.8")
Cut-out:
W 210mm (8.3") - W 300mm (11.8") x H 110mm (4.3")
Weight:
4.98kg (11lbs)
I'm making my own hose kit as I'm putting quick connections to make it easier and will also installing a 12V pump inline when using it for camping.
Getting more prepared for the Northwest Overland Rally next month. Installed my ladder from 4x4labs. Going to make a bracket for my 20lb CO2 tank/ 10lb propane tank
I also installed Metal-tech 4x4 Red Eye Utility Rack w/ licence plate holder and Metal Tech Fuel Can Holder. Lucky I only got 1 to lock the Scepter gas can. If I got 2 and put them side by side, I wouldn't have been able to open my rear hatch. So instead I installed a Military Jerry Can Metal Holder
Love that ladder idea! Issue though. Between that and your jerry cans, where's your tail lights??? Lol. What are the chances of getting pulled over due to that?
BTW, I think you bought the last water storage tank. I was looking at that and now they're out of stock.
Sent from my SM-G920I using Tapatalk
Yah I'm in the process of putting brakes/blinkers on the bottom of the bumper
Mike Sargent
