My LED Project
monostereo said:
i installed the leds and it turned out great. the only thing i didn't like was i put one in the parking lights and it was really dim, but oh well. thanks for the mod. late.
monostereo,
What leds did you install? Did you attempt to make your own or did you buy a premade replacement? I, too, am looking to replace the parking light, but would like it to be at least as bright as the stock bulb it would be replacing. Any information would be appreciated.
Thanks,
Tom
Pennywise said:
monostereo,
Thanks,
Tom
If you want bright one, you have to make it yourself. I did install LEDs which I bought from www.autolumination.com, but I changed to the bulb back due to brightness.
Yeah, I have been doing some research and making some minor purchases for making my own LEDs. I bought the super white 6 leds from superbrightleds.com for the doors and have the super white matrix leds for the running board lights. They are better than the stock bulbs, but I am not too fond of the bluish/purple tint that these bulbs have (too bling, bling for my taste). I purchased some warm white leds and will try to see looks any better.
I also wanted to replace the parking light to be brighter amber and to match the DRL, but the original leds that I bought were too redish orange and not the yellowish orange (amber). I actually purchased some more leds to try out and see what I could come up with.
By the way, the first bulb that I made had a 5mm led in the center surrounded by 4 3mm leds. This is bit tricky to solder and even trickier to fit into the empty wedge. ..
Tom
Tom
just curious did they send you the larger white wedge, or the smaller clear wedge?
The first time I ordered from them, I got the white ones that worked pretty good. Then the second time I got the smaller one, and I haven't even bothered with them. Doesn't look like I could fit anything in them.
I got the small clear wedges and believe me, it was very difficult to work with. My custom bulbs are not as compressed and do not fit as nicely as the premade bulbs do. They stick out about .25" or so and look rather shady with leads sticking out all over the place, but they were my first attempt. They could only get better from this point (so I hope).
Tom
Tom
darn I was hoping they got more of the larger white ones in. Those were easier to work with.
I wish I knew where they buy them from
You could probably send him an email, but I highly doubt he'll give you any information. I have done quite a bit of looking around for empty wedges on the net, but haven't found anybody other than him selling them.
Tom
Tom
Ya I did a bunch of searching too, and came up with nothing.
The running boards take a 194 type bulb, so if your going to go with a plug/play type. You'll want something off this page.
http://autolumination.com/194.htm
From their selection I would get this
http://autolumination.com/matrix.htm
it will help distribute the light more, since it has LED's going in all directions..
I personally didn't like the LED's they used in theirs. They had more of a purplish look to them, and I wanted more of the HID white/blue look. That's another reason why I went with making my own.
Hope that helps
Chris.
sharp4runr said:
http://autolumination.com/7443_7440.htm
Look at the very bottom of this page. It has empty wedges, but I'm not sure if that is what you guys are looking for.
Those wedges they have pictures are the ones I used. But now, when you buy them, they send you a clear wedge that is not as wide on the end. So it's harder to get the leds into it.
If you can get the white ones, then it's easier to do your own.
Thanks sharp4runr,
However, those particular wedges are for the 7443/7440 bulbs, which is the size of our stop bulbs. The wedges needed for the parking lamp is a 194 and the empty wedges could be found on the 194 page at this site. They also have the wedges for 3157/4157 as well. I purchased a few of each (194, 3157, 7443) just to have and, for the record, all of the wedges are clear. cdoyle managed to get some bigger white 194 sockets at one time, and they would be nice, because the clear 194 wedge is hard to work with.
Thanks for throwing that out there...
Tom
if i want to change the dashboard lights to LEDs instead of stock orange. which website would i go to. and which bulb would i get? also how do i acces the bulb?
The dash as far as I know is already lit with LED's
To change the color you would have to unsolder all the surface mount LEDs and then resolder the new ones on. That would be a big job, and I would get a used cluster to practice on.
if i want to change my map lights, door lights, dash lights all to LEDs super white lgihts which website would i get it from? (there are tooo many websites to choose on this forum :) )
do you want to make your own, or buy some already made?
also on the first page the 2nd picture, how you changed your stock amber lights to super white where would i get those. (sorry for all the questions) i'm very excited about ordering my SUper bright LEDs
Then I would just get them from http://autolumination.com
They seem to have a large selection.
Dash lights you will need to find out what type of surface mount LED our cluster has, then try and find some that have the same specs, in the color you want. If you're new to this, I would pass on the cluster for now :)
enunciatechive
