Mysterious cylinder 2 misfire
So I was driving and my 1996 3.4 started jerking and shaking, drove it home and it was a fuel injector...here where it gets weird ...got all new injectors ,new plugs ,new wires ,all new gaskets ,and the coil packs are fine and it holds compression...after changing all those things it still misfires in cylinder 2 WHEN it reaches normal operating temperature... what do y’all think it is and thank you for the reply’s
I know nobody is reading this but The misfire moved from 2 to 4 and I put a new coil pack (just one for now ) and it ran the same so I drove it down the road and it went away drove great then 5 min later it came back same thing ...sooo frigin annoying and expensive
So it wasn't a fuel injector since it didn't fix it Or did you mean that something changed after all the parts were installed? 90% of car repairs take 10% of your time. 10% of cars take 90% of your time. This may be a 10%er
Just saw your 2nd post. MAF sensor? Cylinder running lean for various reasons. Not well versed on the 3.4 yet but will be soon enough
So the misfire went back to cylinder 2?
Is there any vacuum lines connected to the intake runner on cyl 2? A tvs can apply vacuum when it warms up thereby creating a vacuum leak on cyl 2. Whether it would be enough to cause a misfire would be the next question
Not really sure but I’ve checked and have gotten all my vacuum lines checked and everything is working except that cylinder so far nobody knows what’s going on I’m taking it to another mechanic to see what they think ..after that I’ll try to find a computer then a motor
