Leave the valves alone. Who's going to do the work?
Even though I'm a "girl" and don't live in the communist country of Komifornia, I'm doing the work.....
patience and the time to help out a FELLOW member in need in a step by step pattern to save thousands of dollars
As I read through this thread I believe it was members here that convinced me I didn't need a new motor. Is a valve job something I should be afraid of?
If your truck is not misfiring or performing badly it is doubtful you will improve it in any way by doing a valve job. In fact you are more likely to break something that was fine to begin with.
Generally, at least here, we tell people not to fix something that isn't broken.
BTW 16 MPG @ 16 gal = 256 / tank. 300 / tank ? Lol that would be nice but very uncommon.
FWIW, doing a valve job is not gender specific. I know a few women that are excellent Mechanics. What a valve job entails is the proper tools, knowledge and experience to do the job properly.
Adjusting the valves is one thing, (which also requires special tools, knowledge, and experience) but a valve job done properly means removing the cylinder heads to work on them, which requires even more special tools, knowledge, and experience.
I would suggest that anyone asking whether they can perform a valve job, doesn't currently have the necessary tools, knowledge, or experience to perform the job.
Trying to learn those skills on a daily driver, would be an exercise in frustration.
This applies to anyone that wants to acquire those skills: Go to school, gain knowledge on how the various systems of an internal combustion engine work. Gain experience in actually working on the various parts in an engine. Buy the tools you need. Then when you have the knowledge and tools to do the job properly, THEN you should think about performing whatever work your daily driver requires.
About the valves ... I say leave them alone because I'm not sure what mileage you have, you say there are not any real major symptoms like ticking or knocking and that you are not blowing blue smoke. Basically there is not really an indicator there IS something wrong with the valves so why mess with them.
Others may disagree ...
There are some pretty good write ups on how to do the valve cover gaskets. I assume you found the links I posted above.
BTW how many miles? I assume at least 150k if it is a 97.
Also are you SURE that it is a valve cover leak? Posting some pictures would help. I guess if you saw the pictures in another thread then you would know what to look for.
I mainly ask because sometimes people post about a rear main seal oil leak as well.
