So what did you do about the rubbing?
I bought a set of TRD Off Road wheels (the ones that are stock on the off road 4runner) and 275 KO2s for my 16 Limited.
The wheels are 17x7.5. Most other Toyota 17" rims are 17x7 (including the TRD Pro wheels and the SR5 wheels).
I did have to do some fender liner mods to stop it from rubbing in reverse, but that was a pretty easy job.
I just did this on my 2012 Limited. I swapped my 20in stock wheels (hey, anyone looking for a nice set up stock 20 in wheels????) for a set of 2017 trail wheels (complete with barely driven on tires). It's stupidly straightforward. I had Costco do the swap because I needed the TPMS sensors moved as well. It is a dramatic improvement over the 20 in wheels. There are a few people selling Trail wheels down in Colorado Springs - I'm sure there are some good deals up in Denver as well.
Obligatory picture, because I can. Running 265 70/17, and yes, the hideous running boards are the next thing I need to to "fix."
it confuses me how some folks swap to TRD pro rims and 265/70/17 tires and have rubbing and others do not. are certain tires like KO2 and Nitto not exactly true to size? how can this be with stock suspension and no spacers?
toyota dealers recommend (in Canada) for snow tires and rims 265/70/17 tires and replika 17" rims that are 8" wide and 5mm offset - for all trim levels of the 5th gen (wider rims than TRD pro). the TRD pro rims are 7" wide and 4mm offset. I would assume the two toyota dealers I spoke to would not recommend the same set up if it wasn't a perfect fit
people who are smarter than me can you please enlighten me here? I went down a rabbit hole and spent 3 hrs learning about rims, offset, etc. but still couldn't figure this out
I had rubbing on my limited with 265 Wildpeaks. Each 4Runner is just slightly different in the way it sits. That’s why some have the kdss lean, but some still don’t. But some tires run big as well. For instance the Wildpeaks have pretty deep tread but they’re also much more square in the shoulder block whereas the k02 are narrower in comparison.
If switching to a -10mm (or even more negative), 0mm, 4mm offset from the 15mm offset of Limited and TRD Premiun wheels most will likely need to do the fender liner mod with stock tires (265/70r-17)
This is a non issue with the 4runner Pros since Toyota has already done the fender liner mod to the Pros at the port/dealership to fit the 4mm offset of the Pro Wheels.
I switched my 20-inch wheels to SR5 wheels for winter tires, then decided to go to a different set of newer SR5 wheels when I went back to summer. Sold the 20-inch wheels and tires.
Everything was easy with the stock tire sizes. I had a tire shop clone the four TPMS sensor codes to the winter tires, then the same four codes to the new summer tires.
See this thread...
Time for Winter Tire Changeover 2017 LE
