Need an OC Shop to Install Lift Kit
velascokb
Can anyone out there recommend a shop that will work on a 2008 Sport Edition? So far I tried Becker and 4 Wheel Parts. They won't touch the Xreas system even though all I want is for it, along with the stock springs/struts, removed.
I'm leaning towards an OME Low Lift Kit from Slee Off-Road.
Any input is appreciated. Thanks in advance.
Do you ever plan on returning it to stock form? I work at a shop in Anaheim Hills and I see no reason why we couldn't do it but I know the xreas system is tricky to remove if you plan to use it again.
I have no intention of putting it back in. I'll keep the runner as long as I can. Where's your shop? I live in AH, which is a definite plus!
Where in OC? I'm in Huntington Beach. I owned Overland Warehouse that developed the lift kits for 4R and FJ with Radflo. I've installed many kits. Can help you do it. Trust me - its better you wrench on your own truck. Usually takes about a half day to instal. XREAS is easy to remove. :rockon:
Jesse1
