Need Assist from Coil Spring Experts!!
liqourish
So i have Camburg Spindles (+4in lift) with King Coil-over Shocks 2.5(+3in lift)
I need some suggestion on picking out springs that will lower it yet keep it firm. The rears are also lifted around 5.5 inches (kings 2.5 with overland warehouse 3in lift springs and daystar 2.5 inch lift).
Ride is perfect at the moment on 33.4's Duratracs. But I am switching over to stock Wheel size, so i no longer need the excessive lift.
Goal:
Front Lift(4 inch)
Rear Lift(5.5 inch or unchanged)
Reason:
I saw some stock 2016 Rims with stock tires on sale for cheap. THnx
Goal:
Front Lift(4 inch)
Reason:
Crank your front coilovers down. If they have the longer #700 springs this may not work as well but if they have King's lesser spring rate coils then you should be able to get close to stock ride height in the front which would only leave you with the +4" lift spindles in the front like you want. Remove the rear 2.5" daystar spacer and it may be leveled-out. Still, with a 4" lift in front and 3" in the rear, it will look ridiculous with stock size tires.
CoaterZ_FL
