Need help asap, please.
Jordanbiird
So i just found that my left rear spring is out of place. The end of the spring is not all the way down to where it should be.... Where it meets the medal stopping point.
Is this a problem?
To ease enough pressure off the spring do i have to disconnect anything before i try to move it?
I already tried taking off the left wheel and jacking up the left frame pretty high, and theres still too much pressure on the spring for me to turn it.
Any advice please?
It isn't huge, but don't go flexing off road, pushing it to its limit until it is fixed.
Unbolt the shock and sway bar link, then tilt the axle till the spring is loose to be seated correctly.
When i put the shock back on, does it have to be torqued really tight? I tried taking it off just with a normal ratchet and it wouldnt budge..
DionicioLives
