Need Help Finding Ignition Switched Power Wire
Robb235
Senior Member
Need a little help... I know basic things about electronics, like relays, soldering, that kind of stuff. But beyond that, I'm no expert. I need to find a power wire behind the dash or steering wheel that gets power only when the ignition is on. No power when ignition is off. Tapping into this wire, it would only be used as the signal to activate a relay, so there's not going to be a large draw on this wire. Can't use the cigarette lighters because they're now full time hot. Is there another easy-to-access power (that's hot only when ignition is on) that I can use?
leolediola
