Need help with alarm wires!
Suprareal
Alright guys i have a viper 5301 and want to do a basic install with only the alarm,lock and unlock doors. no remote start at all. in my 98 runner
i am not sure where to connect the (-) unlock output, (-)lock output, (-)ground when locked, and (+) door trigger wires. i have everything else hooked up.
ive fallowed the color codes but the keyless remote will not lock/unlock my doors when i connect to these wires so they must be wrong
12volts white - white/red + ignition harness
Starter grn/blk or black + ignition harness
Ignition black/yellow + ignition harness
Second Ignition blk/yel or blk/red + ignition harness
Accessory blue/red + ignition harness
Power Lock red/white - 10 pin plug, left of fusebox
Power Unlock red/yellow - 10 pin plug, left of fusebox
Parking Lights+ green white plug, front of fusebox
Parking Lights- red/white steering column
Door Trigger black/white - Drivers Kick Panel, harness to rear
Dome Supervision use door trigger
Trunk/Hatch Pin red/white - Drivers Kick Panel, harness to rear
Tachometer black ac ignitor or diag. plug
Wait to start
Brake Wire green/white + at switch
Horn Trigger green/red - steering column
ANY help would be great !
the red dots are what i have hooked up and are right. the crossed out ones i dont need. do i need any more hooked up from the H3 connector? thanks
yes it has power locks. and had a karr 2040a in it but i never had the remote.
when i hook up the lock/unlock where the old alarm was plugged into i am unable to use the unlock button on the drivers door and the remote still does not work to unlock/lock.
The horn and lights flash when i press the remote buttons like they should though.
clearly i have the lock/unlock wires in the wrong place but i have tried multiple places and still nothing, or theres a chance its not getting enough power ... ?
did u make sure u unplug the karr alarm harness from the box? maybe u might need a relay hook up to the lock and unlock wire,
yeah i took the karr alarm out completly. and yeah a relay sounds like what i might need, im going to try again in the morning making sure everything is right and ill post back here tommaro
