Need help with Cookie Cutter build
warriorwagner
I'm just trying to verify some parts and how many I'll need:
New OEM-style rubber steering bushings
Energy Suspension 8.10103 - Steering Rack Bushings. Energy Suspension ENE-8.10103G - Just 1?
New aftermarket sway bar links front and rear
MOOG MOOG-k90681 - Front Sway Bar End Link. MOOG MOOG-k90681 - 2(one for each side)
New aftermarket sway bar bushings front and rear
Whiteline W21259G_rear - Rear Sway Bar Bushings - Greaseless -16mm (0.62 inch). Whiteline - 2(one for each side on rear)
Prothane 181115 - Front Sway Bar and Endlink Bushings - 26mm (1.02 inch). Prothane 18-1115-BL - 2(one for each side on front)
Is this what I need?
buy the actual Toyota Sway Bar BUSHINGs. They won't squeak but the poly ones might.
also, have you seen the tutorial sticky? It has all the parts you need.
I've looked in the tutorial sticky and cannot find all the correct part numbers I need, maybe I'm looking in the wrong spots. I just see what to replace (and a lot of those are for 4WD), it doesn't help with part numbers.
Any and all help appreciated.
044runner4
