Need help.
Doc2012
Senior Member
Two plugs behind the radio.
One white 3/4 circle, one grey. Think the grey one was for the stock amp, but don't remember; and don't remember where the white one goes.
Anyone that can help me out would be awesome.
It's not clock, it's not hazard, it's not anything up top. Not climate control.
Pics of plugs:
Thanks guys.
Neither are for the amp. The amp has a wide rectangle plug. Is it something for the transmission shifter or 4WD selector possibly?
99% sure the grey plug is for the power antenna relay.
After looking through the FSM for over an hour and a half, my eyes started hurting.
Anyone that can help me identify where this plug goes, would be awesome.
I don't see that plug anywhere on a 2002. (It doesn't take that long to rule out all of them if you have the EWD. That's a pretty unusual plug.)
What year are you? (It's always good to have that in your sig if you're asking for help.)
i can take the truck dash apart real quick tomorrow and check it out if u would like. whats that bundle of wires its attached to?
From FSM:
Connector type is IJ1 "Cowl Wire and A/C Sub Wire (Near the A/C Unit)"
Hope this helps.
What year are you?
Sorry. Thought I did have that in there. She's a '99 Limited.
I didn't see that in my FSM either. Or a search on here. Or a search of my pics that I have. lol.
That would be awesome man. I would really appreciate that.
In this pic, you can see both of the plugs. The grey plug is the one I'm holding (suspected antenna relay), and the 3/4 circle is in the upper left.
This bundle is the bundle that "starts" (as you're looking at it), from the radio plugs (the two white rectangles on the bottom of the pic, resting on the tranny tunnel), and goes up into the main body harness under the dash.
The grey one is ~6" from the radio plugs, and the 3/4 circle one is about mid way up the dash.
Does that make sense?
Thanks a lot man.
Hope this helps.
It does. Thank you. Where in the FSM was it? Didn't see it in mine?
I just can't seem to find where it plugs in at. It's sitting in the middle of the center, but I'm not seeing the female end anywhere.
Really don't want to take the dash apart again. [emoji22]
Guess I'll have to, unless [MENTION=14772]shootmymime[/MENTION] is able to get a pic of where it plugs into before I get out there around 1130-12ish. Lol.
Look for it on the passenger side footwell.
And it says page 40, but on the PDF its Page 1909 or something
[MENTION=14772]shootmymime[/MENTION] thank you!
That helps a lot. Now, when the kids go for a nap, I can go plug it in. Lol.
Good work, [MENTION=118617]Truck4[/MENTION]. I didn't think to check the wire-to-wire plugs, which have their own chapter. I just checked the main list. Learn something every day around here.
Crookedcat
