Need Quick Help..Will these 33"s fit with my lift?
ar1five
My lift is getting put in as we speak. I picked up a set of 285-70/17s for a steal. Should I go ahead and swap tires over or wait to buy wheel spacers?
Factory 17" wheels
Tires- Buckshot Mudders
Lift- (Front)Tundra coils springs with 1" top plate. (Rear) EMu 890s with blist
33s will rub with your lift. Upon full compression they will top out in the fenders. Usually a body lift is needed to minimize this rubbing, 1"-1.5". I know someone that doesn't run a body lift and his tires rub pretty bad on the top of the wheel wells. You will probably get rubbing on the back side of the front wheelwells when turning hard. Some trimming is usually needed to run 33s. Wheel spacers can increase the rubbing on the wheelwells when turning, mine did.
Factory 17" wheels? 3rd gens never came with 17" wheels. "Factory" as in 4th or 5th gen? What is the back spacing? The stock 16" wheels have a BS of ~4.65". Most 33s will rub the UCAs due to the width/BS. It's close so If your wheels have less BS then they might not rub the UCAs. Some tires are wider than others so some have more and some have less clearance.
NVBASSJUNKIE
