Need tire size help!
Toyo Toyo
I was just wondering I have a 98 limited with a 3in Revtek suspension lift, what could be the biggest tire I could fit the guy at the tire shop told me it would be a 28/5 and I don't know if that's true.
285/75/16 if you are a 16 inch rim. you still may rub a little bit. 1/4 inch wheel spacer would solve the rubbing. or new uca's.
315/70/16
I was thinking some 375/65r16s.
But really, search around. This has been covered. A good answer would be what [MENTION=84737]atxrunner[/MENTION] said. You will probably still rub so stick with 265/75 if you want to have no issues
EDIT: Do you want full lock to lock with out rubbing? I hear even with a 3in lift, you still have to trim to fit 285's.
seltzernator
