Needs some info/opinions on my 93 4R
loko ino
Ok guys..so been thinking about my lift plans.
I want to go up to 32's but don't think that will look good with a 4" lift, so should I get something like OME kit? I think that one comes in 2" right...and is all inclusive so I won't need anything outside of the kit. Opinions?
Second, I am looking for a decent rear off-road bumper, plate, with tire swing and jerry can holders, that is tow rated..anyone got a site I can check out or will I have to get it custom made for the 93?
Third, the rear window button on my center console...can it be fixed to put the window down also? Tried searching for that answer but didn't find anything.
Fourth, any recommendations on roof baskets?
Thanks guys!
You can fit 32s with no lift. So any lift you do will just be for what looks best for your. The ome 2inch kit is very popular though.
I was reading and folks seem to say I will rub unless I do som altering for 32's, is that not the case?
Also, if I do the 2" lift will I still need to buy new rims to accomodate the backspace? Or will the stock rims be ok for 32's and a 2" lift later down the road.
Youll have to trim (or hammer flat) the pinchweld in the front fenders.
As for your rear window button, does the window go down using the key directly in the gate? If so you might just need a new switch. They are in a bad spot, and get loaded up with dirt easily.
yep, goes up fine with the key. My switch does not say DOWN on it, just up but the rocker does move 2 ways so I was just wondering. It goes up fine but I would like it to make the rear window go down also.
ok..for the 32's, can I put them on stock 15" rims and be able to get the 2" lift later?
Im running 33s and dont have a lift. My wheels have a different backspacing though.Only time I rub is if I fully crank the steering wheel.
32 x 10.50 will not rub.
20120915_155522.jpg~original
31 x 10.5 came no were close to rubbing on stock wheels.
IMAG0373.jpg~original
OK..well the wheel shop was cool, they put the 32/12.50s on my 4R and it rubbed...a lot with the rims and the offset I had. I would have had to cut up a lot because they were 12.50s. I went with the 31's...
I'm blinded by the BLINGADYBLANG!!!
LOL!!
I totally went against bling. Dude wanted me to buy some Fuel rims that were like $250 a piece and were all black and chrome...with stars on them.
These pro comps cost me $90 per and should hold up on the trail well.
HMMM..never noticed everyone has their steps removed.
Ok..will do that next weekend. Do I just need to buff out the paint under them?
It looks good dude. I'm lifted 4inches and I removed mine. They're held up by brackets connected to underneath the truck. Only the parts where the plastic is on the fenders covers paint.
What did you guys do about the chrome around the fenders? Can I just pull it off or I need to replace it with something? My toy budget is spent for the month so gotta do the "free" mods for now.
There might be some scuffing under the chrome. I haven't taken the chrome trim off yet. Truck has been down for a while and just got it back. Haven't had the time to mess with it yet.
What are the specs on those pro comp rims? Backspacing, offset and so forth. They look like the 1069's and they look awesome to me and i have been looking to put them on my truck with my tax return.
Thanks,
Jhacker
Thanks,
Jhacker
They are the 1069s.
I'd have to get the specs. The tire guy I go to I trust in his recommendations and these work with 6" lift, if I go that way.
Oh, and wife found me a 1977 Coleman cooler to mount in the back of truck eventually
peacefulpiranha
