>MR2turbo4evr<
I took a closer look today. I couldn't tell that its leaning to the left. Maybe you can. There you go:
>MR2turbo4evr< said:I took a closer look today. I couldn't tell that its leaning to the left. Maybe you can. There you go:
Northof49 said:Both of my 4Runner's (03 and 05) leaned slightly to the driver's side. It's normal.
I imagine it gets more lean the more fuel is in the tank.....which might be why some look different.
4RunnerSE2006 said:Hello,
I just got my new 2006 SE 4Runner a couple of days ago. I noticed today that the car tilts/sags on the left side when viewing the car from rear. Initially I thought it's just poor lighting in the parking area of my building. But I've confirmed it by dragging my wife to the parking area to double check this. It's not the tire pressure issue either as I tried to park the car the other way around. It tilts/sags on the left side either nose in or tail in the parking spot.
Is this normal? I've never had this type of issue with my previous cars. (This is my 1st Toyota and SUV)
It seems the parking spot is uneven. Right side is slightly higher than left. When I say slightly I mean it's less than 1/2 degree. Maybe even less.
Is this normal for a 4Runner when the ground is slightly uneven?
I've tried my other car in the same spot. It's a Prelude and the car is much lower than the 4Runner. I do not notice the sagging or tilting on the left side. Really like to know if this seems normal to you.
Please advise. Your comment on this is highly appreciated.
TC3racerM11 said:Just got my 2006 SE V8 couple weeks ago. I also noticed the leaning rear driver side the other day. Didn't really notice it till I was parking my other vehicle behind it. Been bothering me also. I did have earlier problems with the air pressure sensor always going off when I was parked on a slanted driveway. Got that figured out by putting more air on all tires. I entertained the idea of going to the dealer this weekend to check out the other 4 runners if they had the same lean and asking the service dept about it also. Anyways, glad to find this site, very informative.
Anyone notice the dash near the pedals under the steering wheel? Does it seem to be missing a panel or something? You can basically see the wiring and everything down there. I checked out my buddy's 04 se and an 06 SR5 and they both have the same look. Is it me or is there a panel that belongs there?
thanks
Thai said:Just to show that this problem is not exclusive to 4runners, it also happens on the FJ Cruiser:
http://www.fjcruiserforums.com/forums/showthread.php?t=2945
4RunnerSE2006 said:Thai, Do you know if Fj are made at the same plant?
