New ECU Not Working
gruenegenes
My 4Runner runs fine with the exception of a brief power loss that happens 1 to 2 times/year. Last time the code said the ECU was bad.
I ordered a remanufactured ECU from Flagship One and the vehicle would crank but not start. I sent it back twice and all three units had the same problem - It cranks a but won’t start. I put the old one in and it starts fine. Am I doing something wrong?
2002 SR5 4WD
2002 SR5 4WD
Sounds like the new ECM's don't have your immobilizer programmed into it. What was the original trouble code?
The code was P1129. Details here:
https://www.toyota-4runner.org/3rd-...tent-loss-power-hesitation-2.html#post3793820
Was the immobilizer used on the 2002 model? If so is there a way to program it into the module?
Top: No immobilizer
Bottom: Immobilizer
Which one do you have?
Immobilizer ECU and no immobilizer in vehicle = no start
Immobilizer ECU and mis-matched programming = no start
The immobilizer does not stop the engine from cranking, it stops it from starting.
-Charlie
Top: No immobilizer
Bottom: Immobilizer
-Charlie
Was that only for 01-02? My 2000 Limited had an immobilizer and the keys looked like the top key in your photo.
Top: No immobilizer
Bottom: Immobilizer
-Charlie
I’m trying to upload a pic but it keeps telling me upload failed. The top of the key is thin black plastic. Nothing like the thickness of our 2016 highlander or 2017 tundra. It’s also generic. I don’t think it has a chip in there. Does that mean it does not have an immobilizer?
Your image is too big. If you resize it to a smaller resolution/file size you can upload it.
Elchele89
