New fine-grained VSC OFF Mod for V6 1GR
Wondering if you are able to make it stay off when you turn off the vehicle, I would not want to have to turn it on every time I start the car. It seems that with my larger tires and lift the vsc is kicking in all the time and i just want it off for the most part.
I did not plan to do that as you'd rather not switch if off on a good road. Vsc really helps on a high speed. However, if you really want to do that, you can try to find "Monostable Multivibrator" which will generate single ground impulse every time ignition is on. It is kind of pressing button for you on start.
Kliv great product. Just bought an 07 v8 AWD sport edition and wanted to try and get a unit before the holiday in Russia. I’ll be awaiting a pm.
Much thanks!
2005 2wd v8 sport
What about a 2wd sport. I was in the desert yesterday. I could turn off the lsd button and it would help but I still get the dang beeping going on.
Hey guys,
I'm really sorry, but I'm out of stock and have an issue with the manufacture I used to deal with.
Will update you once everything got resolved.
Where does one acquire the unit and how much is it? Have and 06 V8. New to the forum but have been lurking for months. Thanks for any help.
I've got one for sale that I bought from Kliv a few months ago, installed, and removed from my 4runner. It works perfectly but I decided to go a different route (disabling all the electronic nannies including ABS).
The unit is exactly as I got it, with the exception of a few wires being slightly shorter than original due to being cut during removal. Almost all should be long enough regardless but you may need to extend one or two of them. Comes with the test light, and I'm also including 4 female terminals and wires which can be used to hook up an "FJ" style Trac Off switch. Please PM me if interested.
2001ATL
