"New Grease for the Solid axle"
Oh no you dont,
I can not believe I have let myself get sucked into this thread.
Over it, goodbye. :ybrick:
No you dont just chime in here and spout your propaganda and think your going to get away with it,
With out earning it, So you say you would follow Rixxer and this because he is the educated tech with the experance,
Understood,
Figered that out a while ago, this is why he is being deprogrammed, exit counseled ,,
Random Wheeler Babe
a5038eaf-orig.jpg~original
I think that you should spread this grease and your unique conspiracy theory over at the PriusChat forum! The Toyota Sales folks are very active on that forum...they are actual members. I am sure our twist rear beam needs this grease in one form or another!
Oh ?
Well you know I always wondered if there was some other weird application or problem that Toyota Sales covered up, Dis informed the masses, they may have a different technique over there, would have to study the matter,
But for now all efforts are concentrated on deprogramming Rixxer, then possibly move on to other things, but first things first,
Now as Far as Rixxer seeing the factory grease with his "Own two eyes" and it being a thick #2 grease,
Well,
Quod non capis quod non vides Animosa firmat fides Praeter rerum ordinem
Fides en Toyota Sales,
Vestustatem novitas Umbram fugat veritas noctem lus eliminat @ Toyota 4 runner forums,
Well,
"WELL" Nothing.
I have, and I'm calling you a LIAR, BECAUSE I HAVE.
Your statement that "#2 grease is unacceptable in a c.v. joint is ALSO A LIE.
MANY were posted here:
• View topic - CV Joint lube compilation
(I hope it's ok with the admin to post a link to another forum? If not I will take it down. Possibly NSFW due to language)
And I posted pictures of 2 seperate greases that were very obviously NOT a #1 or #0, that came FROM THE C.V. JOINT MANUFACTURER.
IMAG0106.jpg~original
IMAG0110.jpg~original
IMAG0109-1.jpg~original
Neither of those look like this #0 stuff you're trying to sell now do they?
0529101057a.jpg~original
For the record, THIS stuff works JUST FINE.
IMAG0111.jpg~original
How much proof do you need before you admit you're wrong frank?
Not only wrong about the solid axle trucks and 4runners and landcruisers, but wrong about c.v. joints in general?
How can you continue to spout this b.s. incoherent crap, and actually still believe it?
After market greases
"WELL" Nothing.
There is no Auto manufacture that uses a #2 grade grease, list off all of the after market greases you want,
But the manufactures use a #1 grade or thinner, and this my dear brainwashed Rixxer is the whole base of the subject,
What does Toyota use @ production, it is not a #2 grade,
So call me a liar, just shows your incapable of defending Toyota sales, without insulting, slanderous attacks, but again I know who you should really be insulting, so I sluff them off,
I have worked on factory axles for 20 years, never once have I seen a #2 grade in them, Toyota included,
I've worked on PRIMARILY Toyotas for 15 years, and you are wrong, frank.
That's all there is to it.
Factory Fill requirements
CV JOINT GREASE
EMPI Moly C.V. Joint Grease meets the rigid factory fill requirements set by all major C.V. Joint manufacturers. EP-2 (Extreme Pressure) Additive provides superior protection against seizure under extreme pressure loads. Use EMPI Moly Grease for all long travel play car or racing applications. See page 383 for Bulk Grease.
86-3000 Moly Grease for C.V. Joints, 4 oz. packet
86-3005 Moly Grease for C.V. Joints, 3 oz. packet
86-3009 Red CV Grease, 14oz tube
Okay Rixxer This is BS,
Find me some Factory fill requirements for a CV joint, The GKN aint gonna say use a #2 they say a even thinner than #1 grade for a inboard CV joint,
But is the EP-2 even a #2 Grade ?
The SKL #1 is not #1 grade its #0
Factory fill requirements, Now this is funny , in the process of talking with Moses Ludel he threw out a # and said be sure the grease meets GM Spec # 1954702390 or whatever,
Look up that grease spec and it is non existent, a few greases saying that they do meet this GM spec # but nothing about what this is,
If they do say something about it, like in other grease specs, its just vague terms,
So if that grease is a #2 grade it does not meet the specs for GKN joints, because a GKN engineer clearly stated that the inboard tri pod grease needs to be of a thinner consistancy to work into the lil needle bearings,
A #2 grease is incapable of doing this, so not advised by the manufacture,
Sign it Rixxer, step up, quit being a slanderous brainwashed grease monkey defending the dirtbags that talk **** about you , throw you under the bus any chance they get, call you ignorant,
Step up Rixxer,
I know Rixxer,
Yes I know Rixxer, PRIMARILY Toyotas, Educated by Toyota sales, 100 % Indoctrinated, brainwashed,
If you where to have some experience with other vehicles, and other education then your primary Toyota Indoctrination,
You would see this plain as day !!!!
Sign it Rixxer, Step up ,
What's "plain as day" is how wrong you are frank.
The proof is already out there.
Everyone seems to see it EXCEPT YOU.
Well No
No Rixxer aint just me, we got The old boy "Master of the Obvious" on your hole of the4x4network,
Cj3flyer here on Toyota 4 runners, Kurt Williams knows of the "Correct Fluid grease" for these axles and the 30 year longevity that can be obtained,
Old Jeeper "Red" and various others, thats on line, Oh And I talked to the ASE outfit, they said to sign up on this tech network called IATN or something like that, I did,
Started Talking about this stuff without even mentioning Toyota, and they came back with Oh you mean the stuff in the enclosed axle for Toyotas ?
Yep, So dont need to preach to the choir, plenty of folks recognize this axle and the lube thats in it as a grease,
Usually since it is not available in the general aftermarket mix up some sort of gear oil and grease,
There is Technical Writer Steve Turchet that wrote about the "Bad news" that the #2 grease can bring,
So plenty of others, Moses Ludel knows of the "Mystery greases" used in these import Rigs, Izuzu, Geo
A fluid lube in the wheel hub,
So dont know why you think is just me, plenty of folks, Now less on the internet, but all you have to do is go talk to some shops, lot of them know whats up,
Not just me Rixxer, and if you would talk to the old timer I know that worked @ Toyota,
Look, I was told this grease was private and looked into as to WHY? came out of nowhere, did not know such misconceptions where out there on this subject,
not just me, plenty of "Masters of the Obvious" Seems real simple to me, every axle I have seen, worked on had a #1 or thinner grease, all the way to a oil in a CV joint,
Plenty of commercial grade stuff with oil or semi fluid in the wheel hub ?
So do I need to show you that Honda axle with the semi fluid grease in it again ?
I am not the only one, Oh call ALLDATA, they laughed when they seen Toyota' Sales Recommendation of a #2 moly lith grease,
Laughed @ your stupidity,
Well I dont think its funny, its sad really, Sign it and get out Rixxer,
Seems to me all your "proof" is a ruse, just you grasping at straws.
Alldata?
Some random people that noone has ever heard of.
And then there's frank dunphy, who won't even post the name of the product.
Ole franky is the only one preaching this crap.
Might wanna stop and think why that is.
alldata
Alldata?
Random people ?? they are a massive resource for the auto trade, all sorts of shops pay good money for all data information,
Frank Dunphy, has a product called Backwoodsgoop which is the factory type lube,
Invested good money so I could actually have this grease to show you, to get you out of the Toyota sales cult,
I am preaching because I do not want this to get any worse, you see Rixxer not all Toyota techs stay @ the dealership, they come out into the real world and cause the same problems, because of their indoctrination,
simple as that, Now it was no skin off my nose that this poor Toyota consumer that told me not to do something to his pile I didnt think was right,
had to pay 2 tow bills, another shop to follow the brainwashing manual,
and my original labor as well,
Cost him I figer another 7 bills or so, But he asked for it, and then posted on mud about a backwoods grease monkey not following the FSM, Daring to defy the Toyota sales recommendation,
How dare I ? well long time ago @ transmission seminar the fist thing the Instructor said was, "I dont care what the manufacture says you do what you know""
Because its not a Toyota after I am done with it, its Franks, something goes wrong and Frank has to fix it,
So yes I am in direct defiance of Toyota sales, and their recommendation because if its a matter of pouring in the right grease and getting the thing to last for 30 years, I am doing it, vrs packing in a #2 lithium crap, and getting it to go only 5-10,
Step out Rixxer
and heres all data pitch
Welcome to ALLDATA.com
ALLDATA® is the leading provider of OEM auto repair software to the professional automotive service industry. Thousands of mechanical repair and collision shops across North America depend on ALLDATA automotive software for service and repair information, auto recalls and technical service bulletins. ALLDATA offers shop management software and customer communication tools to help run their business, boost profits and productivity for independent repair shop owners.
Says thousands of repair shops Rixxer, So no one has heard of them ? you havent maybee because your sucking up Toyota bull**** and thinking its yummy, and think all other information is junk,
This is why I call it brainwashing, and the more you post up the more you prove just that,, you just pissed on a good source of info that thousands of shops use,
Thousands, Deal with it Rixxer your brainwashed by Toyota sales, 100 % come on now No ones ever heard of All data ??? Dude, you need to come out of that little World Toyota Sales built for you, a little bubble, call you a "Master Factory Trained Toyota tech"
No a 100 % indoctrinated puppet of Toyota Sales,
Not a Master but a Slave, doing the bidding with out question, with out learning this is the darkness, of which I will pull you out off
Yep
Like talking to a brick wall.
Yep Rixxer, And I am going to keep tossing grease bombs @ your brick wall ,
But your brick wall is built on a web of lies, or a pile of ****, hit it in the right spot and the whole thing come crashing down,
but since there is no "Leaders in the Toyota aftermarket" a new one needs to emerge,
This is the goal Rixxer, you are being groomed for the next leader of the Toyota aftermarket,
Your being re educated, Sign the contract, move on,
Post up the info chicken little.
If you weren't afraid, you would.
You haven't.
Because you're afraid.
You aren't teaching, you aren't undermining, you aren't right, you aren't righteous, you aren't enlightening.
You're
JUST
PLAIN
WRONG
Supervise Dealer Marketing,
You haven't.
You're
JUST
PLAIN
WRONG
Classic, sign the contract, Chicken littler, become the "new leader" and you will know all there is to know ,
You know your not going to get me to post it up, so dont know why you bother, Its Intellectual property,
That Toyota Sales does not want you to own, I will give it to you free, as long as you sign the contract, Step up Rixxer, You see if I tell you my "Secrets" then I no longer have a product, you will just run out and make your own,
So since you have called me a liar 10 million times your lucky I am still willing to talk to you,
But again I know its really Toyota sales that has kept you in the dark, but your here in the light, step up, sign it, learn it,
Then you can be the "New leader"
Does it ?
It just keeps getting better...
Sure does, well Rixxer is curious as to what this is, that is for sure, So maybee that will be strong enough bait to lure him away from the Toyota sales troth he is lapping up everyday,
we will see, Or maybee somebody out of the blue will take the spot that I have prepped Rixxer for,
Dont really care, Some Toyota off roader, fan, needs to step up, Nobody knows me, just a hick in the hills of Idaho with the goop for this axle,
So sooner or later,
