"New Grease for the Solid axle"
Proof positive the grease you're trying to sell is no good, frank.
You know as soon as you post what this crap you're buying from India is, everyone will know, without a doubt, just how wrong you are.
As far as I'm concerned, this is just further proof of how far out of whack you are.
If you knew it was good, you'd post it.
It's not, so you won't.
Pretty simple, really.
From India ?
So a grease from India ???
Hmm You see India does not produce a lot of their own grease it gets imported or @ least thats what I have read,
But for that matter just about all the gears, and finial drive gears I for trannys and rear ends,purchase are made in India,
Yep Input shafts, counter shafts, pinions, ring gears, MADE in INDIA, So ??
Even the 4.88 gears I installed in the Toyota, MADE IN INDIA.,,, So does it mean its crap ?
OR how did I get around Theory #1 Rixxer ?
As soon as you sign up Rixxer step out of the Toyota sales cool aid line You will know,
Maybee I get this grease from Suadia Arabia, ??? or South Africa, ??? or Venezuela , Hugo Chavez and his pals have been brewing this stuff up for over a 100 years, Ship it to China now a days, So ??
And Sure Rixxer This is all new to me as of when Toyota Sales told me it was "Private"
@ First rather unsure if it would be Okay in applications other than this closed axle, but no problems, 2wd wheel hubs, open knuckle, The fist axle I tested this grease in was a 1979 1 ton chevy, over two years ago, Seen it hauling a huge load of firewood down the Road the other day, so Should I take it back apart to see a gob o goo like I stuck in there over 2 years ago, or should I just figer the Toyota "Private" grease is swimming around in that wheel hub keeping things all gooed up happy as can be,?
No it is not from INDIA Rixxer I will tell you that much,
YOU'RE the one that said your stuff came from India.
Did you lie about that as well?
And I STILL don't care what some random person at some other dealership told you, frank.
You Assumed Rixxer
I have never said it came from India,
I allowed you to assume that, and your pals, in the darkness of the4x4network
You will find no post from me that says it comes from India, have never made that statement,
You see all you have is your silly computer, and look and see that India is a Sodium grease supplier,
and ASSUME that it comes from there, NEVER stated it came from India, a Assumption Rixxer,
Your the Random person
Your a random person @ a dealership Rix, and I dont care what you tell me.
because your brainwashed,
Why ? because the Random person @ the dealership I talked to Rixxer, Tells you what to do, and how to do it, and bases your pay on how long he thinks it should take you,
Get it ?
There is a very small amount of entertainment here. . . . . . .very small.:beer:
I wonder if someone is paying the two of you to go back and forth arguing to which neither of you have gained any ground on each other. Why waste so much time and energy with this to which there is no gain. I do have to say though TF. . . . . .even if you were right I would not buy grease from you just because of this thread.:bash:
I just don't like frank spreading this horsepucky around like it's gospel when it's just plain not true.
I really like Toyotas.
I really don't like frank.
Classic,
OH You dont like the deprogramming tactics ? Oh there is plenty to gain, For now I will just be happy it get Rixxer out,
And sure somebody is paying us, Sure, So if you dont want to buy this grease how bout get it For Free !!
Send you a sample,
And your right no ground gained, Rixxer is staunchly defending Toyota Sales position, which will fail, just as soon as some "Masters of the Obvious" step up, You See Rixxer is a follower, as soon as a couple folks start seeing the light, he will as well
Sales or production ?
Toyota production or sales ??, And I know you dont like me, showed up in your little mushroom factories and began your deprogramming,
Its gospel alright, Infallible, studied this matter very carefully every aspect,
Another Intermission
So Today I wasnt able to do a whole lot of exit counseling for Rixxer, but I am sure he didnt mind,
I had to haul a whole bunch of roofing shingles in this here old Truck
PICT0436-1.jpg~original
The Thing only has a little dinky 6 banger in it, a 240 Six, and a little Class 2 tranny leak, leaks about a quart every 2 years,
PICT0435-1.jpg~original
But the thing is solid, ugly as hell beat to hell, but solid, got it for 6 hundred bucks and after 2,000 in tires and brakes I was able to haul, and dump,
whats a little spooky is if your lifting the load out and it gets hung up in the gate, or dont come out fast enough, lifts the frt Wheels off the ground, quite fun, quite the head turner , and the Classic ? Does it dump ? Yep that all works, it aint got no Backwoods goop in her yet but that will change ..
This is old
Screenshot2011-06-17at102011AM.png~original
This whole Oil ? grease deal for a steering knuckle goes back quite a few years actually,,,.
heres some Toyota Trade secret goop in a Izuzu joint, could have been a NTN or NSK these where NSK
DSCN5950.jpg~original
Okay
Free samples! :lmao: Yup not a vendor :police:
Look What good would it do if I where to say "Hey there is a special semi fluid grease that goes in these axles Rixxer"
Ya Whatever . Toyota Sales says #2 and thats the end of it,
No see here it is, See !!
Well What is it ?
Its Trade secret,
Your full of **** !!
No Thats what I have found out, So what good would it do if I did not have a sample, ???
Again before I can become a Vendor I have to deprogram Rixxer, once he "Wises up" Then I can become a Vendor, Actually if your following along here as Far As theory #2 quite possible so "Professional use only type of deal"
Have to be a qualified Grease Monkey to handle this, So maybee no sample unless you can pass the GMA test and prove competent to use this stuff,
So it goes, Now the definition of a "Moderator" is a chairman of any discussion or debate, they need to make the call, Sure I have this grease, wanting to inform Rixxer on what it is, (if he signs) the disclosure contract, This is entirely the "Educational" phase,
Actually in Step 2 or level 2 of the deal, The resistance stage,
Ok, this talking around in circles is boring.
Post up the name of the stuff frank.
If you have the testicles to do so.
Testies
Screenshot2011-06-23at110201AM.png~original
Rixxer, It is Backwoods goop, SKL#1, is the name of it, if you wish to know what its exact Ingredients are you have to sign,
Okay ?
Dont you understand ? It your problem this keeps going in circles not mine, your unwilling to step up and be a leader,
I don't want the ingredients.
I want the name, so the specifications can be looked into.
Your crappy repackaging of a gallon of crap in old coolant bottles and trans fluid bottles, with stickers falling off, is no form of info at all.
Your pictures of knuckle balls leaking all over the place sure is some info though.
You defending it and saying it's supposed to be that way is some more info.
Neither is the info I want.
Post up the name of the stuff, frank.
It's all you got.
Well What is it ?
Its Trade secret,
Your posts make as much sense as two penguins siting on an ice flow eating a candy-bar.
2001ATL
