dr.bjm said:that would be nice but the point of the stealthbox is to save cargo space. i don't want to lose my sounds when i travel and need the cargo space. i sleep in the back on camping trips and things. i live at the beach so i always have cargo. right now i have infiniti kappa 6 1/2 seperates all the way around and my amp is under the passenger seat.
My point exactly....I'm trying to find the least invasive method to get an amp and 10" sub. I was thinking that it would be better to have a shallow box behind the seats versus the stealthbox to the right of the cargo area....I also did not want to attach the amp to the back seat.
The other option would be to build a sub box/amp rack under the cargo shelf...I am pretty sure I can fit it with the 9" depth....but once again....significant loss of cargo area.
I would be very curious to see what amp you have under the seat...can you give me the dimensions of the amp or the brand/model....I assume you have a 4th gen also? This would be a nice option.....a JL 300/4 under the seat, front channels driving some seperates up front, headunit driving the rear doors and rear pillar, and then the rear channel bridged running a JL 8" mounted in the factor JBL sub box.....I need to do some more work on this concept...namely amp mounting space and if there is enough airflow around it so it does not overheat. Then I need to look at the factory sub enclosure and measure the volume. I guess if it was not large enough, then you could have a custom box fiberglassed for the space...sounds expensive.
