New key?
Irhmsd
I just bought a great 2002 limited that came with only one valet key. Dealer tells me they can't program a second key from a valet. They said it would cost $200 to reprogram the computer and flash two new keys. Does that sound right or is there a way to program a master key when all I have is a working valet key?
Yep sounds right. If I remember correctly, they told me the same price but the bill was closer to $300 for the 2 keys. I didn't figure out the whole key thing for months so I was stuck. Since you just bought the truck from a dealer, can't they help you out?
You shouldn't need a chipped key (I don't in my 02). Just go to Home Depot, you can get two for around $5. That's what I did and no problems at all.
35 for the key and 45 to program.
It's done every day by local locksmith, it's not very hard and only takes 10 minutes. Never trust a dealership, they will rob you when they can.
I went to a locksmith today,I have a chipped key for my 2000 that I bought in ebay for 11 bucks,had it cut but lock smith said he could not do a 2000,some years he could and said some years can be done with just a sequence you can do,something to do with having the right equipment,I have to take to dealer(50 bucks)
Well okay some locksmiths are to cheap to spring for the code machine it is a couple thousand dollars. But most locksmith that are bigger then a hole in the wall will have the machine. It's hard for them to justify a code machine for a vehicle that's 14 years old so they spring for the newer machines that have a higher probability of customers coming in. Every vehicle out there save bmw's land rover, Lexus, Mercedes and some year mazda's ( go figure). I'm forgetting a few but it doesn't matter, a locksmith can do it if they are a big enough company to buy the equipment.
Our trucks, are not new enough to have the technical systems of today's cars. Never, ever, should a cost of programming our keys be more then $60 at the very most. Don't let anyone tell you otherwise. Now, if it were something like a new Honda or new toyota it will be more like 250-300 and once again that's mainly the cost of the key, the programming should only run around $100 but that's not for or trucks we have an easy system for them and so it really cheap!
Believe what you may, but I'd never deal with a locksmith that's not associated with AAA. They put very high standards in place for there sub contractors and so you can be assured you are getting a trust worthy company! If you don't believe me just google locksmith scams, and you'll understand!
Yeah lock smith can do it cheaper.
Since we are talking about keys. I have a different key for my ignition which is a pain. Luckly i have the keyless remote but want 1 key to work everything. Can the ignition switch be rekeyed on rhe 4runners? If so i will pull it out either rekey it myself or just take to alock smith to be done.
Yes you can change the ignition cylinder. And if you pull the cylinder out yourself it should be cheap something. Like 15-30 bucks. There are also slots that are split wafer and I would suggest you just leave those empty they have a history of locking up and binding the ignition, and the last place you want to be is in a perking lot unable to turn your ignition.
If you have access to the wafers then do it your self it's easy. You will have to drill the small cotter pin out to remove the inner cylinder from the housing. That's the only complicated part.
Stealerships rule!!!
I just recently went down this road. I lost the only key i had to my 2000 4runner. ALL 3 dealerships (Stealerships here in Cincinnati) said my 2000 4runner has a computer that is non re-programmable and said i would have to wait for a computer from japan (which costs $900) but if i agreed to buy 2 keys, the fee for the computer would be waived. i'd only have to pay for cutting and teaching the keys and teaching the fobs (still totaling over 700 before taxes) not to mention that they said i would need drivers license and registration with matching addresses to prove i own it because they are required to send off copies of paperwork to the govt (oh boy) to comply with certain laws because of high theft rate of this type of vehicle (can you smell the smoke they're trying to blow up my @ss yet?)
well, i called some friends and found a locksmith that could pull the computer, wipe it and reprogram it with 2 keys, no fobs, for 450. done the same day.... needless to say, I told the dealership to not touch my truck and I'd be right there to tow it away. WHAT @SSHOLES.
when in doubt, contact a mobile locksmith
Got mine yesterday from dealer for 50 bucks,all the locksmiths wanted 85 plus,this was just for programing.
I was surprised .
Luceann
